Old 07-10-2010, 02:32 PM
RichrdC RichrdC is offline
Default Sandra Report
I've got two annoying bugs that pop up fairly consistantly..... The problems..... every once in awhile PTMP will stop responding, and I have to sit around till it begins responding again.. Second issue..... All of a sudden, I'll hear a click, and PTMP will have then stopped 'talking' to my Project Mix I/O.... I'm wondering if someone might have any ideas per this long Sandra .. Thanks so much...
Here's the Asus Sandra...
< Computer >
Model: Asus G60VX
Workgroup: WORKGROUP
Host Name: RichNiki-PC
User: RichNiki
< Processor >
Model: Intel(R) Core(TM)2 Duo CPU P7450 @
2.13GHz
Speed: 2.13GHz
Cores per Processor: 2 Unit(s)
Threads per Core: 1 Unit(s)
Type: Mobile, Dual-Core
Integrated Data Cache: 2x 32kB, Synchronous, Write-Thru, 8-way, 64
byte line size
L2 On-board Cache: 3MB, ECC, Synchronous, ATC, 12-way, 64 byte
line size, 2 threads sharing
< Computer >
Platform Compliance: Intel Centrino Duo Mobile Technology
Mainboard: PEGATRON Corp. G60VX
BIOS: AMI 205 08/27/2009
Bus(es): ISA PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support: No
Multi-Processor Advanced PIC (:Yes
Total Memory: 4GB DDR3 SO-DIMM
< Chipset >
Model: ASUS PM45 Mobile Controller Hub
Front Side Bus Speed: 4x 266MHz (1GHz)
Memory Bus Speed: 2x 399MHz (798MHz)
< Memory Module(s) >
Memory Module: Hynix (Hyundai) HYMP125S64CP8-S6 2GB DDR2 SO-
DIMM PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3)
< Video System >
Video Adapter: NVIDIA GeForce GTX 260M (112 SM4.0 1.25GHz,
1GB DDR3 2x800MHz, PCIe 2.00 x16)
< Graphics Processor >
< Storage Devices >
Seagate ST9320423AS (320GB, SA:298GB (C:)
Seagate ST3300622A (300GB, Fir:279GB (D:)
SAMSUNG HD103SI (1TB, FireWire:932GB (F:)
WDC WD5000AAVS-00ZTB0 (500.1GB:466GB (G:)
HL-DT-STDVDRAM GT30N (ATAPI, D:N/A (E:)
< Logical Storage Devices >
OS (C:): 283GB (NTFS) @ Seagate ST9320423AS (320GB,
SATA300, 2.5", 7200rpm, NCQ, 16MB Cache)
SEA_DISK (D:): 279GB (NTFS) @ Seagate ST3300622A (300GB,
FireWire/1394/ATA, 3.5", NCQ)
New Volume (F:): 932GB (NTFS) @ SAMSUNG HD103SI (1TB, FireWire/
1394/SATA, 3.5", 7200rpm, NCQ, 32MB Cache)
My Book (G:): 466GB (NTFS) @ WDC WD5000AAVS-00ZTB0 (500.1GB,
FireWire/1394/SATA300, 3.5", 5400rpm, NCQ,
8MB Cache)
Optical Drive (E:): N/A @ HL-DT-STDVDRAM GT30N (ATAPI, DVD+-RW,
CD-RW, 1MB Cache)
< Peripherals >
LPC Hub Controller 1: ASUS (ICH9M-E) LPC Interface Controller
Audio Device: ASUS (ICH9) HD Audio Controller
Audio Codec: Realtek Semiconductor High Definition Audio
Disk Controller: ASUS (ICH9) Mobile SATA AHCI Controller
Disk Controller: ASUS SD Bus Host Adapter
USB Controller 1: ASUS (ICH9) USB Universal Host Controller
USB Controller 2: ASUS (ICH9) USB Universal Host Controller
USB Controller 3: ASUS (ICH9) USB Universal Host Controller
USB Controller 4: ASUS (ICH9) USB2 Enhanced Host Controller
USB Controller 5: ASUS (ICH9) USB Universal Host Controller
USB Controller 6: ASUS (ICH9) USB Universal Host Controller
USB Controller 7: ASUS (ICH9) USB Universal Host Controller
USB Controller 8: ASUS (ICH9) USB2 Enhanced Host Controller
FireWire/1394 Controller 1: Avlab Technology XIO2200(A) IEEE-1394a-2000
Controller (PHY/Link)
FireWire/1394 Controller 2: ASUS R5C832 IEEE-1394 Controller
SMBus/i2c Controller 1: Intel 801xx/63xx SMBus
< Printers and Faxes >
Printer: Microsoft XPS Document Writer (600x600,
Colour)
Printer: HP Photosmart C7100 series (1200x1200,
Colour)
Fax: Microsoft Shared Fax Driver (200x200)
< Network Services >
Network Adapter: Realtek PCIe GBE Family Controller
Wireless Adapter 1: Intel(R) WiFi Link 5100 AGN (802.11g (ERP),
WEP n-bit, 54Mbps)
< Power Management >
Mains (AC) Line Status: On-Line
Battery No 1: 99%
< Operating System >
Windows System: Microsoft Windows 7 Home 6.01.7600
Platform Compliance: x64
< Windows Experience Index >
Current System: 5.7
<<< Processor Arithmetic >>>
< Benchmark Results >
Aggregate Arithmetic Performan:18.15GOPS
Dhrystone ALU: 22GIPS
Whetstone iSSE3: 14.37GFLOPS
Results Interpretation: Higher scores are better.
Current Processor(s): 5.7
< Performance vs. Speed >
Aggregate Arithmetic Performan:8.53MOPS/MHz
Dhrystone ALU: 10.30MIPS/MHz
Whetstone iSSE3: 6.75MFLOPS/MHz
< Performance Test Status >
Result ID: Intel(R) Core(TM)2 Duo CPU P7450 @
2.13GHz (2C, 2.13GHz, 3MB L2, 1GHz FSB)
NUMA Support: No
SMP (Multi-Processor) Benchmar:Yes
Total Test Threads: 2
Multi-Core Test: Yes
SMT (Multi-Threaded) Benchmark:No
Processor Affinity: P0C0T0 P0C1T0
System Timer: 2MHz
Number of Runs: 64000 / 640
< Processor >
2.13GHz
Speed: 2.13GHz
Peak Processing Performance (P:17GFLOPS
Adjusted Peak Performance (APP:5.1WG
byte line size
< Features >
SSE Technology: Yes
SSE2 Technology: Yes
SSE3 Technology: Yes
Supplemental SSE3 Technology: Yes
SSE4.1 Technology: Yes
SSE4.2 Technology: No
AVX - Advanced Vector eXtensio:No
FMA - Fused Multiply/Add eXten:No
SSE4A Technology: No
FMA4 - 4 Operands Fused Multip:No
HTT - Hyper-Threading Technolo:No
< Performance Tips >
Notice 5008: To change benchmarks, click Options.
Notice 5004: Synthetic benchmark. May not tally with 'real-
life' performance.
Notice 5006: Only compare the results with ones obtained
using the same version!
Tip 2: Double-click tip or press Enter while a tip
is selected for more information about the
tip.
<<< Processor Multi-Media >>>
Aggregate Multi-Media Performa:43MPix/s
Multi-Media Integer x16 iSSE4.:51.45MPix/s
Multi-Media Float x8 iSSE2: 34.5MPix/s
Multi-Media Double x4 iSSE2: 17.67MPix/s
Aggregate Multi-Media Performa:20.20kPix/s/MHz
Multi-Media Integer x16 iSSE4.:24.18kPix/s/MHz
Multi-Media Float x8 iSSE2: 16.22kPix/s/MHz
Multi-Media Double x4 iSSE2: 8.30kPix/s/MHz
NUMA Support: No
System Timer: 2MHz
Rendered Image Size: 1920x1080
< Processor >
2.13GHz
Speed: 2.13GHz
byte line size
< Features >
SSE Technology: Yes
life' performance.
tip.
<<< Multi-Core Efficiency >>>
Inter-Core Bandwidth: 6.41GB/s
Inter-Core Latency: 61ns
Results Interpretation: Lower scores are better.
Inter-Core Bandwidth: 3.09MB/s/MHz
Inter-Core Latency: 0.03ns/MHz
< Detailed Benchmark Results >
Processor Affinity: CPU0-CPU1
2x8kB Blocks Bandwidth: 3.44GB/s
4x8kB Blocks Bandwidth: 3.77GB/s
2x32kB Blocks Bandwidth: 4.63GB/s
4x32kB Blocks Bandwidth: 9.17GB/s
16x8kB Blocks Bandwidth: 8.62GB/s
2x128kB Blocks Bandwidth: 9.38GB/s
4x128kB Blocks Bandwidth: 9.4GB/s
16x32kB Blocks Bandwidth: 9.2GB/s
64x8kB Blocks Bandwidth: 8.64GB/s
16x128kB Blocks Bandwidth: 9.21GB/s
64x32kB Blocks Bandwidth: 9GB/s
64x128kB Blocks Bandwidth: 1.74GB/s
Buffering Used: No
NUMA Support: No
System Timer: 2MHz
Page Size: 4kB
Use Large Memory Pages: No
< Processor >
2.13GHz
Speed: 2.13GHz
byte line size
life' performance.
Tip 11: Use the tab to switch between Detailed and
Combined charts.
Warning 5010: Cannot use Large Memory Pages due to lack of
privileges.
tip.
<<< Power Management Efficiency >>>
<< ALU Power Performance >>
<< 50i/25Hz (25fps, e.g. interlaced PAL video) >>
ALU Power Performance: 9GIPS
Power Efficiency: 0.00
ALU Power Performance: 4.24GIPS/MHz
< APM System Status >
Processor performance boost po:100 %
Minimum processor state: 100 %
System cooling policy: Active
Maximum processor state: 100 %
NUMA Support: No
SMP (Multi-Processor) Benchmar:No
System Timer: 2MHz
< Breakdown at 500 GIPS Workload >
Average Clock Ratio: 100% (2.13GHz)
Average Voltage Ratio: 100% (1.150V)
< Breakdown at 1000 GIPS Workload >
< Breakdown at 1500 GIPS Workload >
< Breakdown at 2000 GIPS Workload >
< Breakdown at 2500 GIPS Workload >
< Breakdown at 3000 GIPS Workload >
< Breakdown at 3500 GIPS Workload >
< Breakdown at 4000 GIPS Workload >
< Breakdown at 4500 GIPS Workload >
< Breakdown at 5000 GIPS Workload >
< Breakdown at 6000 GIPS Workload >
< Breakdown at 7000 GIPS Workload >
< Breakdown at 8000 GIPS Workload >
< Breakdown at 9000 GIPS Workload >
< Breakdown at 10000 GIPS Workload >
< Breakdown at 11000 GIPS Workload >
< Breakdown at 12000 GIPS Workload >
< Breakdown at 13000 GIPS Workload >
< Breakdown at 14000 GIPS Workload >
< Breakdown at 15000 GIPS Workload >
< Breakdown at 16500 GIPS Workload >
< Breakdown at 18000 GIPS Workload >
< Breakdown at 19500 GIPS Workload >
< Breakdown at 21000 GIPS Workload >
< Breakdown at 22500 GIPS Workload >
< Breakdown at 24000 GIPS Workload >
< Breakdown at 25500 GIPS Workload >
< Processor >
2.13GHz
Speed: 2.13GHz
byte line size
life' performance.
tip.
<< 60i/30Hz (29.97fps, e.g. interlaced NTSC video) >>
Thank you everyone for insights into how to fix these bugs... Take care
Old 07-13-2010, 08:31 PM
xps4000 xps4000 is offline
Default Re: Sandra Report
have you updated all your drivers and software? I read some people have problems with 64 bit.
Old 07-14-2010, 07:12 AM
Have you tried a new firewire cable?(I would).
Old 07-14-2010, 07:58 AM
DigiTechSupt's Avatar
Also, it could be that your FireWire controller isn't compatible - it doesn't look like yours is the required TI chipset. Getting a compatible card with a TI chipset will likely fix the problem.
You may also want to do all of the configuration and optimization steps in the General Troubleshooting thread, as something there may help as well - even without a different FW card...
Avid Audio Tech Support
Support FAQ
Old 07-14-2010, 08:21 AM
Thank you so much for the information.. I'll check all this out.. Take care
sandra report vin7 Windows 3 03-26-2014 03:47 PM
Sandra report mickeyrouse Getting Started 3 01-13-2014 05:57 PM
Sandra Report keithaska 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-23-2010 12:43 PM
Thanks! Sandra Report stevegrisham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-08-2009 09:26 AM
Sandra Report Help Please JCWarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-09-2007 05:52 AM
