Dumb Question: Using Insert cable for stereo?
Will an insert cable (1/4" TRS > 2x 1/4" TS) carry a stereo signal into ONE input on a Digi001? In other words, I have a Korg Electribe with L/R unbalanced outs. If I use an insert cable and plug the TRS end into a single input on my Digi001, will it still recognize the stereo signal, thereby saving me from using 2 inputs?
I'd TRY IT instead of asking, but my system is out of order for the next week or two. I had assumed it wouldn't work, but no harm asking. |
Re: Dumb Question: Using Insert cable for stereo?
no. the 1/4" TRS input is BALANCED mono.
the other way around would work: if you connect the TRS end to a portable cd player (via 1/4->1/8 adapter) and the 1/4" TS ends to the 001, you would get the stereo signal out into two UNBALANCED inputs. do yourself a favor and learn what this means. let this be the last time you ask this
Thanks for the clarification.
Lesson learned aaand... DONE. |
dumb question: insert memory location during playback? | Submersible | macOS | 11 | 05-17-2011 12:23 AM |
dumb question - outboard insert delays | banana boy | Pro Tools TDM Systems (Mac) | 9 | 04-17-2007 08:52 AM |
Dumb cable question: AES/EBU to S/PDIF for 001 | el biciclista | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-11-2006 12:39 PM |
Can't insert a stereo plug-in without creating a stereo aux channel?! | Kickin.da.speaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 03-22-2002 01:23 PM |
Dumb question: JV-2080 mono and stereo outs yield identical PTLE tracks? | el biciclista | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-04-2001 12:45 AM |
