Old 11-27-2017, 10:15 AM
Drew Mazurek's Avatar
Default Re: Icon D-Command Cue Monitoring Issues
If there's a patchbay involved, bypass it until you can get it to work.
www.drewmazurek.com
Old 11-27-2017, 12:07 PM
ffarr ffarr is offline
Yes it is wired exactly like this...im not getting c1 or c2 to pass any audio, only Main through Monitor switch on d command.
Do I need to configure this in Settings as a new Pathway?
Frank
Old 11-27-2017, 12:27 PM
no patch bay
Frank
Old 11-27-2017, 01:03 PM
I don't know what that means, sorry.
And it's turned on and correct source is selected on the D Command unit itself?
Click image for larger version
www.drewmazurek.com
Old 11-27-2017, 01:14 PM
yes, selected and turned on
Frank
  #16
Old 11-27-2017, 01:22 PM
And up?
and audio is coming out of the interface?
If audio is coming out of the interface and getting to the X Mon's Cue inputs, they're on, selected and up, but no audio is coming out of the Cue Output, then you must have a faulty X Mon.
Can't think of another explanation.
www.drewmazurek.com
  #17
Old 11-27-2017, 01:37 PM
cue sends are terminated with 1/4 inch rather than xlr, would that matter? getting signal from mains just not cue outs feeding my headphone amp.
Frank
  #18
Old 11-27-2017, 01:43 PM
Try XLRs into something that takes them to confirm. Try the 1/4s into another device. You have to eliminate variables when troubleshooting.
www.drewmazurek.com
  #19
Old 11-27-2017, 02:28 PM
i will try a different sub with xlr ends rather than stereo phono plugs... thinking now that the main signal passes through fine but cue doesn't and might be because I've discovered the phono ends are stereo. Ill keep my fingers crossed. thanks Drew
Frank
  #20
Old 11-27-2017, 02:33 PM
Sounds good. Let us know how it goes.
www.drewmazurek.com
Icon monitoring francois ICON & C|24 7 02-22-2013 07:59 AM
Need Help for Icon D-Command! Insano ICON & C|24 3 03-29-2008 07:20 AM
Icon D-Command Questions DezMented ICON & C|24 2 03-31-2006 05:25 AM
ICON D-Command Steve White Pro Tools TDM Systems (Mac) 2 03-30-2006 04:22 PM
Icon D-Command ?? cachemira Pro Tools TDM Systems (Mac) 4 04-05-2005 03:47 PM
