Old 08-22-2007, 09:34 AM
Imagination House Imagination House is offline
Default Cue Monitoring
Hi all. I have only been on the ICON for a day now, I looked in the manual and searched the forums. Ok, the question is... Is there anyway to switch the monintoring to Cue 1 via the monitor section? I want to hear my headphone mix without patching, just a quick switch to hear outputs 3&4, which feed Cue 1.
thanks..
Old 08-22-2007, 03:29 PM
GlennR01 GlennR01 is offline
Default Re: Cue Monitoring
No. A possible workaround, as suggested by the guys at Digi, was to route the output of the SLS to one of the stereo monitor inputs. But, of course, you lose your SLS capability. I really wish they had thought this one out.
Mac Pro 2013 2.7GHz 12 Core 128GB • Mac OS 10.5.5 • PT Ultimate 2020.5.0 • PT HDX3 • 192 IO x 8 • D-Control 32 Fader • UAD2 Octo Ultimate
Old 08-22-2007, 03:59 PM
Drew Mazurek's Avatar
Why can't you solo your cue send inside PT and if you're using a PFL bus (using 2 more outs of course) you'd be able to hear it that way? I'm not an ICON owner yet so I may be missing something here.
www.drewmazurek.com
Old 08-23-2007, 04:18 AM
Mikey MTC Mikey MTC is offline
What I've done to get around this is to have my monitor mix permanently multed on the (analog) patch bay and one split comes back on Stereo 4 on the XMon. I'm always one press away from hearing it and at the same time I can patch over it if I want Stereo 4 back for some other reason.
Old 08-23-2007, 07:18 AM
Ya the work-around I am using is patching outputs 3&4 (cue1) into Stereo Inputs 1&2. I guess I am not all that surprised that I wouldn't be able to listen to any of the cues from internal routing. At least they did put the Headphone connection in.
Old 08-24-2007, 01:09 AM
Bart HLH Bart HLH is offline
Same workaround as Mikey, works perfect for me.
www.highlakehill.be
Old 08-30-2007, 08:31 AM
Iain Graham Iain Graham is offline
I always had a set of cans plugged into the front of the D-Command.
But I'd rather have had it come up on the monitors.
myspace . com / iain _ graham
Old 08-30-2007, 10:46 AM
So I guess there must be some flaw in my thinking as no one has responded to my suggestion?
I've mocked it up (minus the ICON of course) and it seems to work. Use a bus for your headphone mix, route that to an Aux Input, route that to your outputs used for headphones, put PT in PFL solo mode and when you solo the Aux input, it's sent to the dedicated solo buss you've set up in the I/O window. Does this not accomplish what you're trying to do?
www.drewmazurek.com
Direct Monitoring VS PT Monitoring therecordinghouse macOS 5 11-23-2013 05:18 PM
Record monitoring level different from Playback monitoring level. sonicflwr macOS 1 03-09-2012 10:05 AM
Monitoring through Rosetta vs Monitoring through 003 Rob0214 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-17-2010 03:02 AM
Auto Input monitoring / Input only monitoring - Alt+K AdamPT8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-09-2010 10:50 AM
Monitoring 5.1 [email protected] Pro Tools TDM Systems (Mac) 1 05-23-2001 08:10 AM
