Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 02-06-2024, 10:44 PM
anassau anassau is offline
Default Pro Tools 23.12.1 Splash Screen
So just for a moment I actually saw what plugins were loading above the status bar on the splash screen. Then I upgraded to 23.12.1 and it went away. I liked seeing what was happening as the program was loading. I was doing a new install on a new M.2 SSD.
Where did all the cool info go? Now all I have is the boring status bar and the spinning Waves icon for when the Waves plugins load.
In advance I appreciate your explanation.
Thanks,
Anassau
too much gear for a punter like me
Intel i13-37000K
64gb ram 2 M.2 SSD 2TB each
UAD Apollo USB
PT 23.12.1
loads of plug-ins
An old Korg M1 that I use for a controller keyboard
Old 02-07-2024, 05:00 AM
tope d's Avatar
tope d tope d is offline
Default Re: Pro Tools 23.12.1 Splash Screen
Thanks,
Anassau
Hi anassau,
Can you post a screen recording of your Pro Tools loading screen?
Thanks
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 02-07-2024, 05:23 AM
its2loud its2loud is offline
The new and improved plugin cache in 2023.12.1 changed the way Pro Tools scans the plugins every time it’s launched. This means you won’t see it scan through every single plugin in the launch window. If it gets stuck somewhere, Pro Tools will let you know. For example, if you’re missing a license for a plugin.
This is a good thing. It allows Pro Tools to launch faster and needing to watch the plugin scan isn’t really a necessary thing.
Old 02-07-2024, 07:07 AM
@its2loud and tope d, well i guess some would call that progress. thanks for the explanation
Intel i13-37000K
UAD Apollo USB
PT 23.12.1
loads of plug-ins
Old 02-07-2024, 07:54 AM
I was looking back through an old post of mine from November of last year.
I must have missed this reply. @tape77 replied that if you go into dark mode instead of classic mode you will see what is loading.
But as @its2loud pointed out it doesn't show everything loading because of "The new and improved plugin cache in 2023.12.1"
Dark mode it is for me. Mystery solved.
Thanks again.
Intel i13-37000K
UAD Apollo USB
PT 23.12.1
loads of plug-ins
Pro Tools won't load (no splash screen) Yoshaan Windows 24 03-22-2024 03:17 PM
Custom Pro Tools Splash Screen? slashgim Tips & Tricks 8 06-26-2018 10:51 PM
Custom Pro Tools Splash Screen? bbrocker macOS 0 05-06-2016 10:18 AM
Sizing the Splash Screen. Terry Wetzel Windows 11 12-08-2013 11:31 AM
PT 8.0.3 splash screen. TVPostSound Tips & Tricks 8 12-22-2009 08:00 AM
