Old 08-04-2023, 08:22 PM
DataStar DataStar is offline
Default Pro Tools 2023.6 crashing with VEPro plugin (VSL)
Hello, fellow composer and pro tools users!
I've been having crash problems when opening a session with vepro and the new version of pro tools 2023.6?
I attested to this problem as soon as the update came out but I just had time to test it now. I had crash problems with other plugins in this version too, things that didn't happen before.
when I open the same template/session with the previous pro tools versions and deactivate the vepro link server tracks, when trying to reopen at 2023.6 all opens normally without crashing. Never had this problem before with vienna ensemble pro.
Monterey 12.6.5
Mac Pro 6.1
Ultimate 2023.6 (all good in the previous versions)
Old 09-22-2023, 02:18 PM
SlyComposer SlyComposer is offline
Default Re: Pro Tools 2023.6 crashing with VEPro plugin (VSL)
Hello DataStar,
I have the same issue since 2023.6 and 2023.9 doesn’t solve it.
I think I’ll create a group with all vep instance and deactivate it before saving and closing the session. Reactivate the vep after opening works fine here.
Did you find any better solution?
Thanks a lot
Plugin Alliance Plugin Issue with M1 in PT 2023.3 skipburz Pro Tools 66 08-19-2023 02:16 PM
ARA data crashing PT on session startup - 2023.3 djmhiratzka Pro Tools 1 03-30-2023 07:20 AM
Sci Fi plugin crashing pro tools 2023.3 randb1 Pro Tools 0 03-27-2023 01:23 PM
VEPro Plugin not found in ProTools 12 Session after upgrade from VEP 5 to VEP 6 PT12 z_jerry AAX Plug-ins 4 12-29-2016 06:27 AM
ARC Plugin crashing in Pro Tools mahag 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-03-2008 02:41 PM
