#31
Re: Anyone else with slow graphic redraws in 2018.1
#32
My projects are pretty heavy and pro tools for me, has been the snappiest daw on mac os sierra by far, logic next, then S1, then cubase way behind, which i find really laggy which is a shame. I generally have about 16 vi tracks, 128 midi tracks and 64 - 100 audio. My vi tracks are usually all kontakt. 480 midi tracks means you are doing full orchestrations and film scoring, right? I've never been close to that in my life.. even when i recorded an entire midi opera composition for someone in my pro studio days, the project wasn't that big! That's huge. Either that or you have a massive template so you have access to whatever you need instantly, but you are not actually using midi on 480 tracks
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX |
#33
400 tracks is actually not as crazy you might think: I keep all my keyswitches on separate tracks from the music itself to make it easier to prepare for live scoring (which essentially doubles the track count), and also layer multiple libraries each for most of the major sectional parts - strings, brass, woodwinds. A full string section will run about 50-60 tracks at least. Sometimes 75+, if you're adding in runs libraries - like OSR and Cinestrings - which i rely on a lot for added realism. And I'm on the LOWER end of the template track count spectrum! The final audio output is way more conservative - usually less than 20 audio tracks.
#34
I use all those audio tracks cause all my external synths get recorded and i usually use maybe 64 different sounds a project so there's the 64 tracks. I only use Vi's when i want some realistic strings or something, but still, it's only for ambient or pop :) and the integra is good enough in most situations anyway. I use multiple instances of kontakt rather than a couple with multiple parts and outputs, cause PT balances the load WAY better with multiple stereo instances. way. It's really good to know that even with close to 500 midi tracks, your gui and everything is responsive. That's great news by the way.
#35
*** So, this means the responsiveness issue definitely has something to do with VEP6. **** The thing is, I keep a super tight ship as far as plugins go. i don't really have any obscure plugins (either AAX, or VST/AU). It's pretty much all major developers. my VST plugin folder on my main machine consists literally of these and nothing more: - Waves Mercury + Studio Classics - Vienna Ensemble Pro - Soundtoys - Sonnox - Altiverb - Ozone 8 - Kontakt - Absynth - Guitar Rig - Play 5 (could be the possible culprit?) (I'm a little looser on my slave machines, i haven't checked the VST folders in a while. Could out of date or weird plugins on a slave machine really affect pro tools performance via VEP? Only one way to find out...)
Last edited by fixxer49; 02-12-2018 at 09:45 AM. Reason: bolded the salient point |
#36
Update:
Adding just two blank instances of VEP 6 [unconnected] really messed up the GUI responsiveness. Great, cos I only rely VEP integrating with Pro Tools for... i dunno, everything.
#37
well this is huge news, as i was going to buy VEP this month..THANK YOU for the heads up.. So far i have only been playing with VEP in stand alone mode without PT open, as i am just trying to learn the interface and functions...
gonna run some tests today.. if it slows down the PT gui here too, i won't even continue with the demo.. pro tools is my priority before anything... But at least i'll be able to add a voice to the choir for you whether VEP is causing the same issue here or not. Will let you know by tonight (just before 6am here). Cheers
#38
well... i haven't fully isolated the culprit yet. It's def something INSIDE VEP, but it may not necessarily be VEP itself. And of course, this only started w/ the recent Pro Tools update(s). I need to check my plugins (AU & VST) and troubleshoot a bit more. I've also put in a ticket at VSL.
#39
Solved!
I've got things running pretty nicely now, I'm hiding/unhiding and edit window scrolling my little tush off, AND I've got 400+ tracks and quite a few active VEP instances. My solution: I removed ALL plugins from the Components (AU) plugin folder. After removing all the AU plugs, VEP is no longer causing non-response or GUI lag issues! Not a problem at all for me - I only use VST versions w/ VEP anyway.
#40
Pro Tools HD 2018.1 - Preferences & I/o VERY slow to close | DrFord | Pro Tools 2018 | 4 | 01-26-2018 04:27 PM |
Slow Screen Redraws when multiple plug-in windows open | PatrickCusack | Pro Tools 12 | 2 | 12-09-2017 05:05 AM |
Half-arsed solution for slow screen redraws | ecalcagnino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-08-2003 12:16 AM |
Slow fades, redraws on NuBus PT3 | Steve Cohn | Pro Tools TDM Systems (Mac) | 0 | 07-12-2000 10:58 PM |
Slow screen redraws with quicktime | Xantar | Pro Tools TDM Systems (Mac) | 3 | 04-04-2000 04:23 PM |
