Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 05-16-2016, 12:07 AM
Adreamofficial Adreamofficial is offline
Default MobilePre reboot (DRIVER_IRQL_NOT_LESS_OR_EQUAL (MAudioMobilPrell.sys)
Hi !
Since i'm working on my laptop now, i'm producing music with a M-Audio Mobile Pre audio card. The sampling frequency is the same as my laptop audio card (44.1) so there is no disconnection or everything. So, it works well, except that sometimes (maybe everyday) the PC reboot with a blue screen saying something like "your computer got a problem etc" and the error code is : "DRIVER_IRQL_NOT_LESS_OR_EQUAL (MAudioMobilPrell.sys)". Do you know what i should do to stop having this ? (i often produce and do something else at the same time, on my computer, could that be why ?) Also, is this harmfull for my laptop ?
THanks a lot !
(i want to join a pictures but i cant right ?)
SiSoftware Sandra
ID
Nom de l'Hôte : KyuriPort
Groupe de Travail : WORKGROUP
Système
Modèle : ASUS GL552JX
Numéro de Série : F6N0CV3********
Chassis Système : ASUS Ordinateur de Poche
Carte mère : ASUS GL552JX
Numéro de Série : BSN1234567**********
BIOS Système : AMI (OEM) GL552JX.204 04/20/2015
vPro Intel : 9.00.30.1482
Mémoire Totale : 7.9Go DDR3 SO-DIMM
Processeurs
Processeur : Intel(R) Core(TM) i5-4200H CPU @ 2.80GHz (2C 4T 3.39GHz, 3.4GHz IMC, 2x 256ko L2, 3Mo L3)
Prise/Connecteur : FC PGA947 (G3)
Chipset
Contrôleur de Mémoire : ASUS Core (Haswell) DRAM Controller 100MHz, 2x 4Go DDR3 SO-DIMM 1.6GHz 128-bit, Graphiques Internes
Module(s) de Mémoire
Module de Mémoire : Hynix (Hyundai) HMT451S6BFR8A-PB 4Go DDR3 SO-DIMM PC3-12800SO DDR3-1600 (11-11-11-29 5-40-13-6)
Système Vidéo
Moniteur : ChiMei Moniteur Plug-and-Play générique (1920x1080, N156HGE-EAB
, 15.5")
Adaptateur Vidéo : Intel(R) HD Graphics 4600 (20CU 160SP SM5.0 600MHz/1.15GHz, 512ko L2, 2Go DDR3 1.6GHz 128-bit, Graphiques Internes)
Processeurs Graphiques
Processeur CUDA : nVidia GeForce GTX 950M (640SP 5C 1.12GHz, 2Mo L2, 2Go 1.8GHz 128-bit)
Processeur OpenCL : Intel(R) HD Graphics 4600 (160SP 20C 600MHz/1.15GHz, 256ko L2, 2Go DDR3 1.6GHz 128-bit, Graphiques Internes)
Processeur OpenCL : nVidia GeForce GTX 950M (640SP 5C 1.12GHz, 80ko L2, 2Go)
Processeur Compute Shader : NVIDIA GeForce GTX 950M (2Go)
Processeur Compute Shader : Intel(R) HD Graphics 4600 (160SP 20C 600MHz/1.15GHz, 512ko L2, 128Mo DDR3 1.6GHz 128-bit, Graphiques Internes)
Processeur OpenGL : GeForce GTX 950M/PCIe/SSE2 (2Go)
Dispositifs de Stockage Physiques
HGST HTS541010A9E680 (1To, SATA600, 2.5", 5400rpm, 8Mo Cache) : 932Go (D:) (E:)
Micron_M600_MTFDDAV128MBF (128Go, SATA600, M.2, SSD) : 119Go (C:)
HL-DT-ST DVDRAM GUC0N (SATA150, DVD+-RW, CD-RW, 512ko Cache) : N/A (F:)
Dispositifs de Stockage Logiques
MUSIC (D:) : 466Go (NTFS, 4ko) @ HGST HTS541010A9E680 (1To, SATA600, 2.5", 5400rpm, 8Mo Cache)
A-Dream (E:) : 466Go (NTFS, 4ko) @ HGST HTS541010A9E680 (1To, SATA600, 2.5", 5400rpm, 8Mo Cache)
OS (C:) : 119Go (NTFS, 4ko) @ Micron_M600_MTFDDAV128MBF (128Go, SATA600, M.2, SSD)
Disque Dur : 451Mo (NTFS, 4ko) @ Micron_M600_MTFDDAV128MBF (128Go, SATA600, M.2, SSD)
CD-ROM/DVD (F:) : N/A @ HL-DT-ST DVDRAM GUC0N (SATA150, DVD+-RW, CD-RW, 512ko Cache)
Périphériques
Contrôleur Hub LPC 1 : ASUS Lynx Point LPC Controller
Périphérique Audio : ASUS Lynx Point HD Audio Controller
Codec Audio : Conexant 510F
Contrôleur de Disque : ASUS Lynx Point 6-Port SATA AHCI Controller
Contrôleur USB 1 : ASUS Lynx Point USB xHCI Host Controller
Contrôleur USB 2 : ASUS Lynx Point USB Enhanced Host Controller #2
Contrôleur USB 3 : ASUS Lynx Point USB Enhanced Host Controller #1
Contrôleur SMBus Système 1 : Intel ICH SMBus
Imprimantes et Fax
Imprimante : Microsoft XPS Document Writer v4 (600x600, Rendu des Couleurs)
Imprimante : Microsoft Print To PDF (600x600, Rendu des Couleurs)
Imprimante : Foxit PhantomPDF Printer Driver (300x300, Rendu des Couleurs)
Imprimante : Canon Inkjet Type4 Class Driver (600x600, Rendu des Couleurs)
Services Réseau
Adaptateur(s) Réseau(x) : TAP-Windows Adapter V9 (Ethernet)
Adaptateur(s) Réseau(x) : Realtek PCIe GBE Family Controller (Ethernet)
Adaptateur(s) Réseau(x) : Bluetooth Device (Personal Area Network) (Ethernet)
Adaptateur Sans Fil : Intel(R) Dual Band Wireless-AC 7265 (802.11g (ERP), WEP n-bit, 54Mbps)
Gestion de l'Énergie
Batterie Nbre. 1 : ASUSTeK GL552JX 48.00Wh/3.20Ah
Système(s) d'Exploitation
Système Windows : Microsoft Windows 10 Personnel 10.00.10586
Compatibilité de Plate-forme : x64
Asus ROG Windows 10
8Go Ram
Cubase 7
M-Audio Mobile Pre
A-Dream
MobilePre reboot (DRIVER_IRQL_NOT_LESS_OR_EQUAL (MAudioMobilPrell.sys) Adreamofficial Le Forum en Français 2 06-06-2016 06:03 PM
Driver_IRQL_Not_Less_or_Equal cabdriver Windows 24 03-26-2016 08:40 AM
Mobilepre USB? velvetlounger General Discussion 5 12-13-2012 06:45 PM
DRIVER_IRQL_NOT_LESS_OR_EQUAL, then- BSOD TOMsubG Pro Tools SE and Essential (Win) 0 11-28-2011 04:57 PM
driver_irql_not_less_or_equal / BSOD when shutting down zygzag420 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-24-2007 11:54 AM
