Old 08-04-2012, 02:44 PM
Danny Winn Danny Winn is offline
Default Accidently closed my Tracks window, how re open?
Ok, this is really stupid but I accidently closed my Tracks/Edit window (Showing instruments and wav forms, Not the Mix window) and I cant figure out how to open it back up. I even reopened protools but its still missing. It doesnt appear to be in the "windows" drop down menu.
Im sure its simple, can somebody help a bro out?
Thanks
Old 08-04-2012, 02:48 PM
Drew Mazurek's Avatar
Default Re: Accidently closed my Tracks window, how re open?
Press: Command =
www.drewmazurek.com
Old 08-04-2012, 02:51 PM
Originally Posted by dmazurek View Post
Press: Command =
I tried Control = (I'm on PC) but it didn't work, nothing happened. Any other ideas?
Thanks for responding.
Old 08-04-2012, 05:18 PM
The Weed's Avatar
The Weed The Weed is offline
Are you holding down Ctrl when you hit "="? They have to be together, not one after the other.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 08-04-2012, 08:17 PM
phatbeatstudio phatbeatstudio is offline
at the very top where your apple icon is ,you will see it says Pro Tools, go across from there near the end it says window, click window , now there are a crap load of thing to pick from the drop down, click on either mix or edit which ever you need. This will do it .
the short cut for edit and mix are command - or + . they have to be at the same time. or continuously holding command then - OR + at the same time .
If all this doesn't bring up the screen you have likely dragged it off screen and cannot see it when it does toggle
Old 08-05-2012, 02:12 AM
Bill Denton Bill Denton is offline
And if you have accidentally dragged it offscreen, you can temporarily adjust your video card's resolution to a higher value.
This will allow you to see more of your "desktop". You can then drag the Edit window to the upper left of your visible window. Then reset your resolution to its original value.
Note this will rearrange all of your desktop shortcuts, but real men don't use desktop shortcuts anyway...
Good luck...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Timeline Window accidentally closed roger_official Windows 1 12-22-2013 10:54 AM
Can't save with 'tracks' window closed? RaySoul 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-23-2009 06:27 PM
sessions always open with mix window track list open jaglance Pro Tools TDM Systems (Mac) 2 08-03-2009 06:03 PM
Closed or Open Backed Headphones? GTBannah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-16-2008 11:07 AM
Can't open groups & tracks sidebar in Mix window Slink69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-24-2007 12:09 PM
