Re: PreSonus Firebox issues with Pro Tools 10
Thanks for your help ! |
Have you contacted PreSonus support? They seem to be pretty good at getting back to individual users.
No, I hadn't. This is a good idea, I will contact them.
Thanks Again |
Have you tried changing the sample rate setting under Setup->Hardware in PT?
It's possible PT can't find a match since the Firebox is using odd sizes. |
In fact pro tools display the message at startup : "Your audio device is configured with an unsupported audio buffer size. Please select one of the following supported buffer sizes in the device control panel: 32 64 128 256 512 1024 2048"
And then close. If I press N while loading i can change between asio4all and firebox asio driver, select the number of samples but it has no effect, the same message displays. And I don't know the key to get to the hardware dialog at startup (if there is any) |
with PreSonus FireBox | Fritz | macOS | 1 | 11-24-2012 05:12 AM |
Presonus Firebox with PT10 | BohoProAudio | macOS | 0 | 07-13-2012 11:26 AM |
Pro Tools 9 Compatibility Issue with Presonus Firebox | tryn2chanjdgame | Pro Tools 9 | 0 | 02-12-2011 06:11 AM |
PT 9 and PreSonus Firebox | DWJr | Pro Tools 9 | 10 | 12-25-2010 08:11 AM |
Mbox (2) and PT LE vs PreSonus FireBox w/Cubase LE | mRoy62 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-04-2005 10:41 AM |
