Old 10-25-2018, 01:04 AM
Melody Man Melody Man is offline
Default Xpand2 plug-in settings sellect button not working.
In Xpand2 I would have a midi file on an instrument track. I would go to the box that says plugin settings select and click it. From there I could go through and select a sub menu which would bring up the box with the patch names. I now click on the box and nothing happens. The + and - buttons don't work either. How do I fix this.
Old 10-25-2018, 01:30 AM
Stig Eliassen's Avatar
Default Re: Xpand2 plug-in settings sellect button not working.
Works fine here (Mac). If you click on <Factory default>, do you have presets there?
Old 10-25-2018, 08:29 AM
No. I click it and it shows a drop down box that says <factory default> with a check mark next to it and nothing happens. It has been this way for the last 3 updates. I go to the presets arrow and try to load settings and get no where.
Old 10-27-2018, 12:47 AM
Maybe this thread can help.
Old 11-01-2018, 02:02 PM
Thanks for the suggestion, but that did not work for me. I am on a PC. This was from a Mac guy. I tried anyway.
Old 11-02-2018, 01:33 AM
How about this article?
Old 11-11-2018, 02:36 PM
Thanks for the reply. I did this procedure and it would not prompt me for navigation to the root settings. It will only allow me to put a check mark next to the root settings. I have gotten patches to show up in the box now, but it will not give me access to the full patch category menu. I can only load one category at a time, through a long process and that gets old fast. I just want it back like it has been for years.
how to get xpand2 plugin-ins settings select to work Waverly Harris Pro Tools 10 7 10-25-2018 10:22 PM
XPand2 Not working with PT 10 Upgrade novellorecording Pro Tools 10 7 08-30-2017 12:06 PM
Your Kensington Trackball Button Settings... sinnic Pro Tools TDM Systems (Mac) 8 11-30-2016 12:11 AM
Xpand2 and TL Metro not working michaelraymoore13 Windows 6 10-07-2012 06:13 PM
Xpand2 Not Working jimst57 Pro Tools 10 5 02-22-2012 04:00 AM
