Old 11-25-2008, 04:04 AM
mongoman mongoman is offline
Default protools export audio
hello new to the forum .. im using pt/le 7.3 and
i cannot get the export audio function to work ..
i record a mix back to track and then i highlight it
go to export but only midi is highlighted even though its an audio file ..
what am i doing wrong >.?? thanks much..
Old 11-25-2008, 08:03 AM
Tim Gale Tim Gale is offline
Default Re: protools export audio
Try this. Use the Selector tool and click off the timeline. Then double click on the mixed down audio track. That should highlight only that region in the Regions Window. Then either right-click or click the Regions title bar and select "Export Regions as Files..." and set your settings and export. That should do it if I understood your post correctly.
Old 11-25-2008, 08:27 AM
shea shea is offline
I think what he is trying to do is save the highlighted file to disk,but I think he should be using bounce to instead of export in the file menu.
seamus
Old 11-25-2008, 10:01 AM
mano111 mano111 is offline
In the regions menu make sure "select parent in project browser" is checked.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Old 11-25-2008, 10:16 AM
DigiTechSupt's Avatar
What are you highlighting, exactly - the track name or the actual recorded region on the track?
You need to be selecting the region.
Also - where are you selecting 'export' from? The regions bin?
Avid Audio Tech Support
Support FAQ
Old 11-28-2008, 08:41 AM
i appreciate all the comments.. answer to tim gale..
i was selecting export from the file menu...
maybe i should select from the regions bin .?
ill try it all and adv over weekend thanks...mucho...
Old 11-28-2008, 08:53 AM
JMS40 JMS40 is offline
Bounce to disc...
Export MIDI to Audio in ProTools? gilorlev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-28-2008 07:21 AM
protools OMF export therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-31-2008 05:57 PM
AUDIO EXPORT FROM FINAL CUT TO PROTOOLS herbyherb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-06-2006 05:30 PM
Protools AAF export MattV Post - Surround - Video 8 08-28-2004 05:48 AM
OMF export from ProTools 6 philper Post - Surround - Video 3 11-21-2003 01:55 PM
