Surround capable audio interface for working from home
Hi to all!
Looking for some suggestions. Many of us working in Post during this pandemic have been forced to work from home. Looks like it will be mine turn as well and need to prepare fast. What surround (5.1 monitoring) capable audio interface do you use in home work setups? I see that there is almost no middle ground between stereo and 16/32 IO interfaces. Especially little information is on 5.1 monitoring capabilities. Investing in Avid HDX system would be overkill for home work - dialogue editing, backgrounds, music and maybe some premix. |
Re: Surround capable audio interface for working from home
Focusrite & Metric Halo come to mind as both have monitoring abilities built-in. You could use both of these with PT Ultimate without needing to buy HDX or HD Native cards.
-Chris
• MacPro (4,1 to 5,1) 12 Core 3.46 GHz // 96GB // AJA Kona LHi // OWC Mercury Elite Pro Quad, USB 3.0, eSATA • PT HD|Native 2024.3 on macOS 12.7.4 (OpenCore Patcher 1.4.3 on Crucial SSD) • Avid Dock, iPad 7th gen & EuCon 2023.11 • DADman/Eucon monitoring • BSS (DAN + 100), QSC DCA 1644, JBL 7 Series • MTRX Studio // 7.1.4 www.quesound.com |
UAD Apollos give you up to 7.1 surround monitoring control.
I have good experience with the Focusrite RED4 Pre. Works with either PT (Core Audio, ASIO or Digilink) or other DAW´s. You´ll need a thunderbolt enabled computer. Provided your monitoring is on an analogue path it will work OK as it has 8 DA´s. You will also get Dante on board. For monitoring control, if you prefer hardware, I would suggest checking from the Drawmer range, good quality sound without breaking the bank. Focusrite is also about to release a monitor controller, the R1, which will work with any Dante enable product of their range via Dante. And it´s surround capable as well. https://www.drawmer.com/products/mon...&series=moncon https://www.drawmer.com/products/mon...&series=moncon https://pro.focusrite.com/category/a.../item/red-4pre https://pro.focusrite.com/category/a...item/rednet-r1 Hope it helps!
Regards, Paulo M MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura Protools Studio 2024.3 |
RME / Fireface. Very stable. There are extensions to put it into 19"
Béla Brandes | www.bbsounddesign.de |
Apogee Quartet is a nice little thingy for 5.1 monitoring.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
The Metric Halo ULN8 (or LIO8 if you don't need the preamps) is a great box; full surround monitoring capability and it has very comprehensive DSP built in for any kind of speaker correction you may want to do. Their GUI 'console' is very capable if a bit 'head-scratching' at times.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Thanks for the recommendations! Very much appreciated!
Will start to do research and comparisons on them! They all sits in almost same price point. I am not found of idea on built in DSP but that may just be my own bias what I need to get over with. Just can't imagine how I would use it at this moment. Seeing 8ch of AES on ULN8 are very welcome sign since I will pair upcoming interface with Genelecs and they have AES inputs. Few decent preamps will find their use as well. Actually I haven't heard of Metric Halo before and I don't have idea how they stand against Avid hardware. |
Speaker correction (eq and delay), Bass management come to mind immediately. See here: https://www.pro-tools-expert.com/hom...tor-controller If you don't need/want any of that then the other reccs could all work - the new Rednet R1 looks pretty cool if you're looking to integrate into an existing Dante system.
Will protools ignore other devices capable of being used as an interface? | joeydego | Pro Tools 2018 | 1 | 10-05-2018 10:39 AM |
Protools 10 & Audio Interface for Home Studio | MikeHacker58 | Getting Started | 2 | 07-10-2013 05:07 PM |
Hands up who requested a surround-capable Expander plugin from Avid?? | ilovemyssl | Pro Tools HDX & HD Native Systems (Mac) | 11 | 01-29-2013 12:18 PM |
Multi client capable midi interface | kirkgale | MIDI | 0 | 01-25-2009 12:47 PM |
M-Box at Home, Cheap M-Audio Interface at Work? | Kindly Killer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-17-2007 07:02 AM |
