Old 02-01-2008, 06:54 PM
Moz Moz is offline
Default 7.3 versus 7.1 on G4?
Cheers!
Coul'd anyone tell if v7.3 of ProTools LE works better than 7.1 on G4 (Powerbook)?
Thanks.
-Powerbook G4 1.67GHz, 2GB RAM, (OS 10.4.8).
Old 02-01-2008, 07:09 PM
MrBibidy MrBibidy is offline
Default Re: 7.3 versus 7.1 on G4?
I skipped 7.3 and went to 7.4 but from what I have heard from all the guys at the studio I work at it gives you a bit more power back. 7.1 was pretty rough.
James Hurley,
Int'l Freelance Producer & Mix Engineer
http://www.Abravemix.com
Old 02-02-2008, 06:41 AM
Moz Moz is offline
Thanks MrBibidy.
Did you (anyone, please) think 7.4 it's to much heavy for G4 1.67GHz? 7.3 it's better choice?
-Powerbook G4 1.67Ghz/2GB RAM/OS 10.4.8/Digi002R
Old 02-02-2008, 09:03 AM
sunburst79 sunburst79 is offline
FWIW our expirence on the PC side of things would tend to indicate that 7.4 saps about 10-15% of the systems resources over 7.3. This may not however directly apply to Mac.
A 1.67 PowerBook is no longer considered that speedy and I would look very carefully before putting 7.4 on it.
My expirance with my MacBook Pro was that a session running 2 instances of Eleven would run comfortably under 7.3 but I could only run 1 instance under 7.4, It would almost run under 7.4 but not quite. This was as I recall with Elastic Audio turned off.
The amount of RAM you have would likely be crucial also.
Has Digi qualified 7.4 on a 1.67? I haven't checked the compatibility Docs. It seems to me that it could possibly be pretty borderline from a performance point of view.
7.4 brings a lot of good things to the table but it comes at a bit of a cost has been my expirance.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 02-02-2008, 09:45 AM
Brad Gillie Brad Gillie is offline
I upgraded from 7.1 to 7.4, and I'm very happy with the performance of 7.4. I have not had any CPU Usage Errors since upgrading. I typically use 12 tracks with about 5 to 8 plugs per session. You can see my specs in my signature.
96 i/o versus the 192 i/o? Loudnoize Ent. Pro Tools TDM Systems (Mac) 11 11-14-2006 03:05 PM
96 versus 88.2 khz Sambuca Pro Tools TDM Systems (Mac) 6 05-14-2005 10:31 PM
Mac G4 versus G5 versus Windows XP progress88 General Discussion 22 09-08-2003 09:45 AM
M-149 versus? DougP General Discussion 15 10-03-2000 06:38 PM
