Exporting Reason Files to Mix in PT - Loss of Quality
I've been "Striping" out Reason files (exporting them as AIF's, then importing them into PT to Mix) and I have noticed they loose an edge.
My question is this: how, since Reason only exports stereo files, do you properly pan files to achieve the same sound. I have been leaving files panned dead center, then importing it into PT and discarding one side if all I want is a mono file (sub bass, for example). Panning the instrument hard left or right yields the same results. A lot of users complain about the low output volume of Reason, but I usually just bump up the master fader and I think it sounds pretty good. Any advice is greatly appreciated. Thanks, Andy |
Re: Exporting Reason Files to Mix in PT - Loss of Quality
"I'm spunky, I like my oatmeal lumpy,
All you posters in the top ten, please allow me to bump thee" |
I've been slaving Reason to PT via MIDI Synch. I was concerned that if I just bounced an AIF that it might not hold synch. So, I recorded directly out of my mac into PT. I found that what I recorded in was totally acceptable. A good gain structure always makes for a better recording, though.
It would be nice if either Digi would support ReWire or Propellorheads supported Direct connect (or whatever that's called). |
Questionable quality loss | JimHalpert | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-17-2010 05:39 PM |
Is there ANY loss of quality when duplicating? | cheekypaul | Tips & Tricks | 2 | 02-22-2005 10:18 AM |
Quality Loss When Consolidating Audio Files? | David "Doc" Herbert | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-15-2004 02:35 AM |
Upsampling 48k to 96k Quality Loss? | perspectrum | Pro Tools TDM Systems (Mac) | 1 | 02-23-2004 09:25 PM |
LOSS OF QUALITY 24-16BIT | Tell | Tips & Tricks | 2 | 10-10-2001 08:00 PM |
