Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 10-23-2017, 11:27 PM
notedmusic notedmusic is offline
Default External Power Supply HD Omni Thunderbolt Core
Where can I buy an external power supply for HD OMNI Thunderbolt HD?
I want to use HD Omni Thunderbolt with adaptor to USB-C Thunderbolt 3.
It is a bus-powered adaptor but I'd feel much safer using an external power source.
Mine didn't come with a power cable for some reason, where can I buy just the external power by itself for the HD OMNI TB Core unit?
Composer/Sound Designer
Pro Tools 11 HD, 64Gb ram, 12tb SSD, 1909
HD Omni/Thunderbolt Native
A bucketload of libraries
www.Reverbnation.com/jedediahjenk
www.soundcloud.com/jedediahjenk
notedmusic.wix.com/jedediahjenk
Old 10-24-2017, 12:17 AM
Default Re: External Power Supply HD Omni Thunderbolt Core
They run OK off Thunderbolt 2 bus power and Thunderbolt 3 power delivery is relatively over engineered, I would just run it off the Thunderbolt 3 bus power.
Old 10-24-2017, 12:59 PM
Thanks for the info. I guess it would work on TB3 then.
Just in case though,
I reached out to a reseller and I was told that AVID HD OMNI uses these specs (correct me if I'm wrong).
12V 1.0A DC 5.5MM - 2.5MM
So I think this would work?
https://www.amazon.com/T-Power-12V-1...+5.5mm+-+2.5mm
Old 10-27-2017, 10:06 PM
I just tried it using this https://www.akitio.com/adapters/t3t
It doesn't work. No power to the HD OMNI TB.
Old 10-27-2017, 10:12 PM
What does not work? Is the Omni connected over Digilnk (it won't work without that)? What exact symptoms?
On what exact make/model computer? If Mac what model number or date code (Hopefully a recent MacBook Pro or similar. Not a MacPro (USB only not Thunderbolt 3) or PC (likely not Thunderbolt 3))
You have a Digilink (if Pro Tools HD >= 12.6) and Pro Tool HD license assets on an attached iLok 2 or 3?
Do you know the HD native box works on a Thunderbolt 2 computer?
Why are you not using a Apple Thunderbolt 3 to 2 adapter?
Old 10-27-2017, 10:17 PM
HD native thunderbolt box works for sure on a thunderbolt 2 system.
Using USB-C Thunderbolt 3 it doesn't work. I'm not sure why.
It might be a problem with the TB3-TB2 T3T adapter.
Are you saying that TB3 and USB-C though they are exactly the same size aren't the same?
I talked to an Apple representative who told me that they were in fact the same.
For the record it's windows machine with USB-C 3.0.
I'll try it with the apple one and see if that works.
Old 10-27-2017, 10:22 PM
It is what exact Windows PC? Motherboard etc.
USB-C is *not* Thunderbolt. It's a physical connector standard that can carry Thunderbolt 3, USB and various video standards. On most PC's it will only be carrying USB 3/3.1 Gen 1 or USB 3.1 Gen 2, it might even only be USB 2 (esp. for portable/mobile devices). You need to know that the motherboard or a special plug in PCIe card (specific to that motherboard) is providing Thunderbolt 3 though that connector.
So again what exact PC/motherboard or plug in thunderbolt card do you have?
Old 10-28-2017, 08:39 AM
Uh oh, I have a bad feeling... on a PC your best bet may be picking up a used HD Native PCIe card, or if you just need a Omni class interface just using an ASIO interface.
Old 01-11-2018, 09:44 AM
Dan IceWood Dan IceWood is offline
Can I just check something?
The OMNI does not receive power except through an IEC (kettle) lead input.
You have that connected right?
Omni w Thunderbolt and HD I/O 16 X 16 kwa Buy & Sell 1 12-08-2016 09:39 PM
Core Audio Problem - HD Native Thunderbolt w HD OMNI ozanesen Pro Tools HDX & HD Native Systems (Mac) 4 07-03-2014 03:55 AM
Would this UPS (Uninterrupted Power Supply) protect and power my gear? D_Japan macOS 4 07-24-2011 04:23 PM
002 power supply/bad power harness? please help :( djkiller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-07-2005 08:04 PM
Phantom power and mic with power supply? hotstuff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-20-2005 12:56 PM
