Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 11-04-2018, 02:21 PM
BScout BScout is offline
Default Re: Two aggregated interfaces plus two ADATs. Is it possible?
Originally Posted by xrekcor View Post
I have an old Novation ReMOTE 25 and although it has a USB port my MBP doesn't seem to want to recognise it.
Save yourself the hassle and get this working. Install the USB drivers (it isn't class compliant so won't be recognized without them)
https://customer.novationmusic.com/s...product=ReMOTE
restart. plug in.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
Old 11-04-2018, 02:24 PM
* Now I did see a post some months ago about this and did spend some time trying to locate that thread before posting here so apologies if have upset someone for posting here.
* I have also tried creating various aggregates (singles) especially where the UR44 is concerned it seems to work fine. Just can't seem to run the two together. So Darryl's post above seems ominous but maybe there is something I could try.
I was thinking is there a way of making PT see the UR44 first as the first 6 I/O's and the TF5 taking up the rest. I assume the MIDI would be available if the UR44 is available in any case since it is only a trigger and doesn't need an input.
Also, you don't need an audio device part of your playback engine to use the MIDI ports. They are handled separately. So use your UR44 as the playback engine and then look at MIDI devices and you'll find the TF5.
Old 11-04-2018, 03:10 PM
xrekcor's Avatar
xrekcor xrekcor is offline
restart. plug in.
Thanks, I have been looking for this for awhile but couldn't find one asocciated with my particular unit. If this works for my old unit and I could plug in with a USB won't need the UR44 I be happy Chappy
Cheers
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 11-04-2018, 04:56 PM
xrekcor's Avatar
Big thanks BScout, all working now!!!!
no more MIDI cables and even the power supply as the ReMOTE 25 gets power from the USB.
Rob
no sound with aggregated device / 32 channel limit? syndicat Pro Tools 12 5 07-05-2017 11:23 PM
Using eleven rack as part of pro tools aggregated device dmunozcrema Eleven Rack 0 08-26-2015 08:34 AM
Pro Tools Only Sees 1 of 2 Aggregated Motu Interfaces TriValleyScott Getting Started 4 07-29-2014 12:26 PM
Anyway to get pt to work with mac's aggregated device? Logic Pro Pro Tools M-Powered (Mac) 3 11-10-2008 05:59 PM
Is 6.9.2 avaliable for "Aggregated Device"-Feature Zettt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-02-2005 01:52 AM
