I just did a search of the forum and can't find anyone reporting this problem. Basically, the fader won't move, even before Pro Tools is launched. It doesn't seem to recognize that it's being touched. I had this happen on my first MC mix with fader #7 and after a couple of attempts to fix it, Euphonix swapped out the unit for me. Now the problem has returned after about 4 months on the replacement unit on fader #1.
The fader doesn't pair up properly in the hardware test and swapping the plastic touch cap or taking it off to make better touch contact has no effect on the problem. I thought I'd try to research to see if this has been a common problem or is something strange going on particular to my studio before I call them again. All the other functions of the fader strip work properly and if I move the fader within pro tools, the fader on the mix will move accordingly. |
Please, do not be offended, just to rule out the most obvious question - you do always put your finger "in" the button and never push it from "below"?
I haven't heard of anyone else having this problem with the MC Mix and mine's working just fine... No noise and no fader problems so far.
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8, Digi002 Fact., Logic X|FCPX|Motion Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix |
Not offended, but that's not it unfortunately. I've had HUIs, Mackie Controls, etc. I tried the hand cream on the finger tips, etc and gotten other people to touch them just to make sure it's not me. Got the latest version of PT and the latest firmware. I've cleaned out all the software and started from scratch, but even with no ethernet cable, the first fader resists movement. You can force it, but it bounces back. Normally before Pro Tools is launched all the faders will move freely.
What I'm baffled about is that this is my second unit that's developed the same issue and I don't see anyone else reporting this issue on the forum. Neale |
You seem to have done almost everything. Are your mixing faders in the Pro Tools software marked Latch or Read and write? Do you have anyone with Logic 9 software so you can test if it behaves the same in Logic?
(What is the serial number of those two MC Mix? Are they manufactured at the same time?)
Fader not responding to touch | PTPerson | ProControl, Control|24, Command|8 | 5 | 06-09-2012 12:29 AM |
C24 fader touch issues | ziggy2282 | ICON & C|24 | 9 | 02-15-2012 11:22 AM |
D-Control Fader Module Not respond | Xenon | ICON & C|24 | 3 | 11-06-2006 01:11 AM |
Fader doesn't respond. Quicktime errors. | Sunzate | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-03-2005 04:50 PM |
01v...Does Protools respond to it's fader moves? | inimitable_ingress | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-12-2002 12:40 AM |
