Does LLM Low Latency Monitoring Work on Avid HD I/O's?
I've just installed my first Native PCIe card into my 12 core 3.46GHz 2010 Mac Pro running into an 16x16 Avid HD I/O interface box. I am running Pro Tools HD 12.5.0 and have PT12 HD auth on my iLok.
Under the menus, I have enabled Low Latency Monitoring with the checkmark. However, on the Outputs page in the "I/O Setup" window, there is no Low Latency Monitoring checkbox in the lower right corner nor is there the drop down menu to select LLM outputs. There is nothing relating to Low Latency Monitoring at all on the Outputs page in the "I/O Setup" window. What gives?!? Could it be that the 16x16 Avid HD I/O interface box does not support LLM?!? Or is this a bug that there is no LLM options on Outputs page in the "I/O Setup" window?
Mercy Sound Recording Studios NYC http://www.mercysound.com/ facebook.com/mercysound/ instagram.com/mercysoundstudios/ Next Generation Pro Tools-Realize the only plugins needing to be active are on the track you're currently editing & those affected by it...all others should be quickly, seamlessly and auto background rendered into audio. Now dust off your G5s. Last edited by relaxo; 04-20-2017 at 05:11 PM. |
Re: Does LLM Low Latency Monitoring Work on Avid HD I/O's?
Yes, LLM works with the Avid 16x16 Avid HD I/O interface box into a Native PCIe card. I reinstalled a different version of PT HD and it works now.
Mercy Sound Recording Studios NYC http://www.mercysound.com/ facebook.com/mercysound/ instagram.com/mercysoundstudios/ Next Generation Pro Tools-Realize the only plugins needing to be active are on the track you're currently editing & those affected by it...all others should be quickly, seamlessly and auto background rendered into audio. Now dust off your G5s. |
Could you run DigiTest to check whether your interface needed a firmware update?
To be clear:
For HD this is only an HD Native option. Not HDX. "HD Native, 003, 003 Rack, 003 Rack+, and Mbox Pro systems can use the Low Latency Monitoring"
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
Low latency monitoring in non Avid interfaces | flautista | Pro Tools 10 | 11 | 01-08-2012 06:13 PM |
low latency monitoring doesn't work on 002r latest drivers | jntracks | Windows | 26 | 03-31-2011 11:23 PM |
AVID - Low Latency Monitoring bug in PT9.0.1? | paul_g | Pro Tools 9 | 13 | 02-13-2011 12:29 PM |
AVID Mbox3 Low Latency Monitoring w DSP Cue Mixer panel ? | roger.g | Pro Tools 9 | 0 | 11-10-2010 04:35 AM |
low latency monitoring doesn't work | slingerland | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-13-2008 11:13 AM |
