Old 01-28-2010, 03:20 PM
Timmus Timmus is offline
Default 003 and Mbox 2 Mini - Do I Need to Install Pro Tools LE Twice?
Here is my setup:
MacBook Pro 3.06 GHz
4 GB RAM
Mac OS X 10.5.8
003 Factory Desktop
MBox 2 Mini
Pro Tools LE
I'm away visiting my inlaws and broke my phemur which has stranded me in Ohio for three weeks longer than anticipated. So I went out and purchased a MBox 2 Mini and an Axiom 25 to help pass the time.
My question is; if I already have Pro Tools setup to run with my 003 Desktop, do I need to install it again to work with the MBox 2 Mini?
Thanks for the help!
Old 01-28-2010, 03:26 PM
bfx bfx is offline
Default Re: 003 and Mbox 2 Mini - Do I Need to Install Pro Tools LE Twice?
Nope, just plug the Mbox mini in and you should be good to go.
Mac Pro 8-core 2.26 | 6 GB | OS X 10.6.8 | PT LE 10.0.0 | MBox 2 / ECHO AudioFire PRE8
MacBook Pro i5 2.3 | 4 GB | OS X 10.6.8 | PT LE 10.0.0 | MBox 2 / ECHO AudioFire PRE8
Old 01-28-2010, 03:33 PM
You just need to change your I/O options by selecting "default" after starting Protools with a different interface attached. Remember the Digidesign interfaces were not designed for hot swapping. Do a system shut down before disconnecting.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 01-28-2010, 03:42 PM
Thanks! For all the help. Everything is running.
Strange install problem MBOX 2 Mini + Pro Tools LE amarucci777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-26-2010 01:47 PM
003 and Mbox 2 Mini - Do I Need to Install Pro Tools LE Twice? Timmus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-28-2010 07:41 PM
cant install my Mbox Mini dannykoryto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-12-2009 09:25 AM
MBox 2 mini/pro tools 8 LE install error Menulo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-27-2009 01:47 AM
Can't get Windows XP to install Mbox Mini for Pro Tools 8 installation jacobmoon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-05-2009 08:22 PM
