Old 02-12-2015, 05:51 AM
kaioflex kaioflex is offline
Default Re: Blackmagic Intensity Pro & Pro Tools 11.3 HD = Horrible video playback
Originally Posted by Brandonx1 View Post
I switched my video hard drive to an ssd. That helped a lot. I am actually thinking of raiding 2 ssds just to kick up the performance a little more.
I already tried playing video from my internal SSD. also tried with Apple Pro Res and DnxHD36 Codec from different projects - just the video track.
I will try performance with mountain lion soon.
Old 02-18-2015, 04:31 AM
having also problems in shutting down system (after clean install of OS and PT11). Shutting down hangs--
activity monitor says:
MC Client
QT OP Server
ProTools OP Server
ProTools QT Server
callservicesd
identityservicesd
all these threads are not responing
I might need to re-install everything. For sure NOT Yosemite with PT11
Old 02-18-2015, 06:44 AM
BiggiT's Avatar
BiggiT BiggiT is offline
Same problem here..
Mac Pro 4.1
MAC OSX 10.8.5
Processor 2 x 2.26 GHz Quad-Core Intel Xeon
Memory 16 GB 1066 MHz DDR3 ECC
PT 11.3.1
Intensity pro/ driver- 10.8.5
Video hangs for 2- 3 sec
Tried all kinds of codecs, but still same.
BUT ... PT 10.3.9 is works flawless
Old 02-23-2015, 05:02 AM
PierrevC PierrevC is offline
Default Blackmagic Intensity Pro & Pro Tools 11.3 HD = Horrible video playback
Just tried the newly released BM video desktop drivers 10.3.7 with 11.3.1 it looks to be as stable as PT 11.3.0 with BM 10.3.4. Had to try as sometimes the video playback was out of sync and it drives me crazy editing foley. No video hangs at the moment like we had with BM 10.3.5. Lunchbreak is over so back to work for now...
iSeeSound.be | Audio Post Production
Old 03-01-2015, 03:51 AM
My findings for now is that these drivers/pt version combo is the best I had since 11.
Still some issues with image sync when using prores though. But most of the time it's ok.
Confirming also that DNxHD seems to be a bit more stable but not without problems... Sync issue chimes in now and then when stop an playback sequence in fast pace. @Avid: We call that editing someting we do on a daw now and then. ;-) [sarcasm off]
I also discovered that turning off gpu accelleration helps a lot for h264 codecs, which seem to be unusable until now.
  #16
Old 11-29-2017, 11:52 PM
marilo marilo is offline
Have had horrible problems since my update to PT 11.3.2. Haven't been able to use video at all. Tried to downgrade to Desktop Video 10.3.4 with no result. Now upgraded to 10.9.7 and it looks better. We'll se if it's good enough.
HTML code is On
No video out to blackmagic intensity pro PT11 redsixmix Pro Tools HDX & HD Native Systems (Mac) 3 03-23-2014 04:40 PM
No video out to Blackmagic intensity pro redsixmix Pro Tools 11 3 01-16-2014 11:02 AM
Blackmagic Intensity playback garimpo Post - Surround - Video 4 11-22-2010 07:00 AM
Blackmagic Intensity Video Offset Question Nathan W. Post - Surround - Video 1 05-11-2010 11:37 AM
Solved! Rough video from the Blackmagic intensity lode Post - Surround - Video 3 06-24-2009 12:50 AM
