#71
Re: Sample Rate for professionals
I usually do if I'm setting up a new session myself. But if a session is sent to me a certain way, I tend to just leave it. Most that I get are 24/44.1.
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
#72
#73
I guess it would be a dull, colorless world if we were all the same!
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
#74
This is true. LMAO!!!
#75
There is without question an audible difference between 44 and 88/96. We did an extensive test at our facility with a few engineers and in *every* case the high sample rate version was identified without any struggle. This was acoustic music, though it was simple to spot it with albums like Thriller, too. Just last week I was popping back and forth between 44 and 88 and my wife, who's no audiophile, had no trouble spotting the differences.
There are amazing recordings at 44, no doubt. But the engineer gets the credit, not the science. That same engineer, with the same material, and a higher sample rate, will get an even BETTER sounding album. We have proof because many albums have been released in multiple sample rates. You can compare for yourself. |
#76
No wonder I’ve avoided this thread for the last week !!!
I will continue to stay away - carry on
#77
What converters? What amps/monitors?
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
#78
I'm actually glad that I suck enough as an engineer that I don't have to worry about these things...
#79
How should that be possible. Thriller was recorded analog and the digital master for CD was done in 44,1 kHz and 16 bit. Where did you get hi-res files? Are these really done from the original Master-Tape? Or is this some conversion from the SACD original, which was remastered by Bernie Grundman for SACD. To what did you compare it to then? The Master differs from the Original, which has little to do with the resolution. How can you make sure that the files really only differ in resolution and not in gear used or tweaks made.
Mac Pro 3,7 GHz Quad-Core Intel Xeon E5 Mac OS 10.15.7 ProTools Ultimate 2020.11 Video Slave 4.3.477 |
#80
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7 |
Hopefully an easy one for you guys: Opening 8 KHz sample rate / 16 bit sample size | sample | Pro Tools 11 | 2 | 02-24-2016 01:04 PM |
Focusrite Saffire 56 Sample Rate Problems - Sample rates changing during start up | finalcut | Windows | 12 | 02-20-2012 04:00 AM |
Bit Rate / Sample rate | supersam83 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-25-2010 08:55 PM |
MBox Micro Sample Max Sample Rate Only 48 kHz? | Joe Sciacca | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-07-2008 12:52 PM |
Bit Rate/Sample Rate problem? The chipmunks? | bspro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-17-2008 05:40 PM |
