TotalMixFX and Eucon Artist Mix
Hello
I can't get my Avid Artist Mix to work with TotalMixFX on my laptop (PC). It works perfectly on my desktop DAW (PC). I did exactly the same on my laptop: - Intalling latest versions of RME drivers and Eucon, - go to the Eucon Control Panel and setting up Mackie Control for TotalMixFX for midi ports 1-4 - go to MIDI setting in RME TotalMix and setting MIDI connection In/Out to EuMidi1, nnable remote controller select "in use" number 1. - enable midi control in TotalMix FX options. I've noticed on little difference: when i open the tab "assign" in EuControl while TotalMix is open on my laptop the name of my workstation is NOT shown in the applicaton line: It shows: "application: TotalMixFX on " On my Desktop DAW it shows: "application: TotalMixFX on DAW" When i open Nuendo on my laptop the workstation name is shown in EuControl and my Artist Contoller works: "Application Nuendo 7 on Ultrabook" Thanks, Martin Fireface UFX2 latest Driver Eucontrol 18.3.0.244 DAW and laptop both PC, Windows 10 Home Realtek PCIe GBE Family Network Controller on laptop |
Re: TotalMixFX and Eucon Artist Mix
Can I ask you to uninstall (using the installer and uninstall everything option) Then put v3.7 on and try. After that update(don't uninstall 3.7) to 18.3 again. Let me know ?
3.7 download |
Hello Eddie, thanks for your reply!
I did what you asked me, but it made no difference. EuControl still could not make a connection between my workstation and the application "TotalMixFX" But then i tried something: - I kiled TotalMix and the RME driver in system tray. - deleted the Midi assignment in Eucon Contol Panel - made a new assignment for MidiPort 1-4 to TotalMixFX (Mackie Protocol) in the Eucon Contol Panel - resartet RME TotalMixFX And then everything worked fine. But after a restart again no connection between workstation and totalmix... so it seems to be a small problem somewhere in the midi assignment. how can I fix this in a way that it also works after a restart? Thanks in advance, Martin |
Can I change Eucon Layouts with an Artist Mix or Artist Transport? | amathie | Artist Series | 10 | 09-21-2017 07:29 PM |
Eucon sees my Artist Mix as an MC Mix | TheDavidLim | Artist Series | 1 | 11-29-2016 09:42 PM |
Bug for Artist Transport since EuCon 3 | Voyageur | Artist Series | 5 | 08-04-2016 11:58 PM |
Artist Mix/Eucon Problem | digitalpapaya | Artist Series | 0 | 04-19-2016 12:44 AM |
RME TotalMixFX maps only to unit 1 | Raphie | Artist Series | 0 | 11-23-2014 06:59 AM |
