Old 07-13-2017, 05:41 AM
domilik domilik is offline
Default waves insert mapping got mirrored
Hey there,
I installed my ProTools on a fresh system, via EUCON I have a S3+Dock attached.
For some reason, now the insert-plugin mapping (of my waves-plugins) on S3 is mirrored horizontally. Means, that for example that when I Switch to insert-control, Band1 of the WNS is now the very right knob, the HighFreq is on knob No1.
How can that be? It seems that other third party plugs are mapping like I am used to it.
PT Ultimate 2023.12
Win10 Pro 64bit, 64GBRAM
MacStudioMax, 64GBRAM, 32GPU, Monterey
MTRX Studio, HDnative, RME UFX, Yamaha 01v96i, S3, S1, PT Dock, Nuendo 12
Old 09-08-2017, 01:51 AM
Default Re: waves insert mapping got mirrored
No idea?
It's still the same problem, my waves plugin knobs are in wrong order on my s3... It's so hard to work this way.
PT Ultimate 2023.12
Old 10-26-2017, 09:05 AM
I re-installed EUCON, re-installed all waves, trashed PT-Prefs.
Still no success.
So I try it here once more with a bump. Anybody with a suggestion please? This is really a huge issue for me in daily mix work.
(the mapping order is screwed up only in ProTools, using waves and eucon in Nuendo (VST) the mapping is correct, as it used to be on my "old" PT DAW)
PT Ultimate 2023.12
Old 10-26-2017, 05:40 PM
EddieJones's Avatar
EddieJones EddieJones is online now
This has to be fixed on the Surface, it's not really Waves fault. Somewhere back before my time, the order of the knobs was decided (sometimes wrong) If you notice the DYN knobs are backwards but EQ is right. Waves have made their knobs look right on vertical strips, like S5, S6 and S5MC but they appear backwards on EuControl laid out horizontally. We have a task to switch the DYN and Inserts among other changes to make this better. Unfortunately, it will require some plugins to update their maps after. In the long run, it will be much better. I'm trying to push this through as soon as possible.
Old 10-30-2017, 02:15 AM
Thanks Eddie,
what does concern me is, that on my previous system everything was fine. This "wrong order" came up after a fresh install on a new PC. So that was just a coincidence?
And - as I said - on VST no problems at all...
PT Ultimate 2023.12
Old 10-30-2017, 09:20 AM
EddieJones's Avatar
The plugin maps are stored within the plugin. So I suspect on the new install you downloaded new versions of the plugins.
Old 11-04-2017, 07:45 AM
hugoleitao hugoleitao is offline
Originally Posted by domilik View Post
Hey there,
I remember that one of waves recent updates got this fixed, but after further updates seems broken again, using WNS is a mess this way...
April 19th, 2017
Version 9.91 across-the-board update of all Waves plugins.All plugins now have control mapping for Avid S3 and S6 control surfaces.H-EQ: New H-EQ Lite components that require less CPU and are well suited for live sound or when processing resources are limited. They do not include the Spectrum Analyzer and Analog sections.H-EQ: New Solo function - Any parametric band can now be soloed by touching its Frequency, Q, or Gain controls. This provides a momentary check of the band’s processing. For a latching solo of a band, click on its solo button.H-EQ: New Smooth feature which eliminates noises that can occur while controls are moved in certain older H-EQ versions. When a session with instances of older H-EQ versions loads, ‘Smooth’ will automatically set to Off. New instances of H-EQ in new or old sessions will load with Smooth On.Nx Virtual Mix Room: Support for up to 6 Nx Head Trackers at the same time.Nx Virtual Mix Room: Nx Head Trackers can be renamed from the WavesHeadTracker application. The name is permanent and saved on the Nx Head Tracker device itself.Nx Virtual Mix Room: The Head Tracker's status color is now also shown in the plugin's tracking device drop down menu.Waves Central 1.3.1.4: Support for installing version 9.91.
Old 11-04-2017, 07:52 AM
EddieJones's Avatar
Unfortunately, some plugins were mapped backwards some forwards. We are adding more instructions for developers in the SDK to guide them in the right direction. We are also going to add an option to reverse the Inserts whilst this all gets straightened out. Waves are actually doing it right, once all the other plugin manufactures change theirs the pref will become permanent. This was due to the separate teams working on different EUCON surfaces (S5, S6, S5MC are correct), now they are all one, this will get sorted.
Old 11-04-2017, 09:00 AM
thanks for clarifying
Old 11-04-2017, 12:50 PM
Hopefully this can be fixed soon, intuitive controlling of (especially) "frequency-based" plugin-GUIs is nearly impossible this way.
It used to be so great having the WNS on the S3 faders before...
(PS: Hey Hugo, so nice to see you in "my" thread, remember our japanese-diver-mix in Berlin? :) )
PT Ultimate 2023.12
WAVES V9.91 now has control mapping for S3 & S6 mattrixx Avid S1, S3, Dock and Control App 8 04-21-2017 05:08 PM
Waves ICON mapping colinweeks ICON & C|24 7 04-16-2007 09:55 AM
WAVES plugs not mapping Don Geppert ICON & C|24 5 01-29-2006 02:38 PM
Mapping Mapping Mapping! Please Digi, Hear Us... relaxo MIDI 0 11-03-2005 09:44 AM
Waves L2 Only in Audiosuite - Not Insert Plugin?! yarrick19 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-05-2005 07:30 PM
