Trouble with Key Assign
Hi..
Does anyone have problems performing Key Assign for the built-in Compressor using the Main Surface? I do.... I can't seems to configure the key assign channel, from other key channel. Anyone? Jimmy Singapore |
Re: Trouble with Key Assign
Jimmy,
There is no external key available for the built-in compressor/limiter. You can only use the channel signal itself as the key input, and use the two filters to shape that signal as needed. The built-in expander/gate does allow for an external key. You make this assignment on the screen via the menus in the Dynamics Key section. While I agree it would be nice to have full external key support on the built-in Comp/Lim, you can easily workaround this limitation by using a compressor plug-in. Almost all compressor plug-ins have external key facilities. Hope this helps, -Matt
Matt Peterson Avid Audio |
Hi Matt,
Yes, I can assign the key via the screen menues. However the manual says that you can do it on the surface, I copied the following text from the manual: "To select the key signal for the Gate from the control surface: 1 Go to the appropriate Input Channel and target the Gate in the ACS Dynamics section. 2 Press the Key Assign switch. 3 Press Select on the channel you want to use as the side-chain key signal. 4 Press Key Assign again to confirm the assignment." I couldn't make the "key assign" switch to work as decribed. The switch doesn't even light up. It seems that this switch is useless at the moment (or maybe I don't know how to do it)? |
Hi Eytan,
This feature isn't implemented yet, but that's how it will most likely work in a future version of the software. Our manual writers are just a little bit ahead of the game . Sheldon |
HDX can't assign voices? | tribase | macOS | 1 | 03-22-2012 09:19 PM |
Dual screen, Video trouble. Not that kind of a trouble... | 11miles | Pro Tools TDM Systems (Mac) | 1 | 09-25-2009 09:28 AM |
How to assign different samples to each key?? | hed | MIDI | 24 | 09-08-2005 01:29 AM |
installing new TDM - how much RAM to assign to PT? | Namaste | Pro Tools TDM Systems (Mac) | 2 | 12-23-2003 06:08 AM |
assign ram | littlebear | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-09-2001 09:54 AM |
