Axess mfc5 with eleven rack - Help
So I have an eleven rack and just recently traded some stuff for an Axess MFC5 midi controller.
I do have the manual but I must be missing something.... This is my first experience with midi-anything. Does anyone else have this midi pedal? How do I go about getting this working with my Eleven Rack? THX! |
Re: Axess mfc5 with eleven rack - Help
Program change messages should be pretty easy. By default, the program change messages map as follows:
PC 1-4 -> A1-4 PC 5-8 -> B1-4 PC 9-12 -> C1-4 .... Providing that your pedal is set up to send program change, just connect the MIDI out of the pedal to the MIDI in of the 11R. Select some presets and see if they change on the 11. Turning effects on and off is done using Continuous Control messages. You can find a list of them in the 11R settings menu or in chapter 9 of the Users Guide You will need to set your pedal to send a CC message matching the number assigned to the effect. Sending a value of zero will turn off the fx, sending 127 will turn it on. So for instance, to turn the Mod fx on and off you would send MIDI CC 50 with a value of 0 to turn it off, and CC 50 with a value of 127 to turn it on. |
Check out the Eleven Rack Presets Matched for Eleven plugins by Pro Tools Expert! | Justin1524 | Eleven Rack | 0 | 11-27-2015 02:53 PM |
Eleven Rack and Cubase Eleven Rig L/R input NOT WORKING !!! | quebecguitare | Eleven Rack | 1 | 09-01-2015 11:40 PM |
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? | Rongpat | Eleven Rack | 8 | 02-11-2014 07:42 AM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Eleven Rack and Eleven Rack control window not matching | 11R Newbie | Eleven Rack | 3 | 04-18-2012 06:07 PM |
