Buzz from Eleven Rack into PT 12
Hi Guys-
I have begun getting a slight buzz on all of my 11 Rack patches when recording into Pro Tools - I am running HD 12 via an Omni- best described as a relatively high pitched buzzing that is noticeable only while the guitar signal is audible, not on "idle" so to speak I do not get the sound in stand alone mode from 11Rack via headphones. I have checked (to the best of my ability that is) cables, other power sources etc. The sound is the same from different guitars, with different cables, and does not change if I move guitar positioning or cables or the like... It is present on all patches... I have read through the threads regarding buzz and such, but they seem to be about constant sound even when not playing - I have turned off the noise gate on the various patches with no result - I have cycled through the true Z settings to no avail... Have unplugged, restarted and the usual... Any suggestions as to what could be causing this and what to try to fix it? Again, It has not been this way forever, only recently, and without any changes (purposeful at any rate) on my part... Thankful for any help- Frank
Ahoskie Computer: 27" iMac (late 2013) 3.5 GHz processor 28 gb RAM Nvidia GeForce GTX 775M Graphic Card with 2048 mb OX X 10.10.4 2 x Glyph GT50 external drives (3 T each) PT: Pro Tools HD Thunderbolt (PT12) via Avid Omni Eleven Rack |
Re: Buzz from Eleven Rack into PT 12
Is the Omni and 11R connected via s/pdif?
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Hi!
Yes it is.
Eleven Rack Output to Amp buzz | antonis | Eleven Rack | 45 | 10-31-2017 06:59 AM |
Eleven Rack Buzz | CeresRegnum | Eleven Rack | 19 | 03-22-2013 11:41 AM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Eleven Rack and Eleven Rack control window not matching | 11R Newbie | Eleven Rack | 3 | 04-18-2012 06:07 PM |
buzz on the eleven rack | padraic | Eleven Rack | 14 | 02-02-2012 02:44 AM |
