Quickest way to select a gap between two regions ?
I do use some workarounds for doing this: select the exact gap between the end of region and the beginning of the next. But there's some key command I must be missing or that doesn't work for me. thanks for any input
Making sounds and music. Love both. |
Re: Quickest way to select a gap between two regions ?
Place your cursor just before the end of the first region. Hit TAB to jump to the end of the region, then SHIFT-TAB to select to the next region boundary.
STeve
macmandigital.com |
Felix
http://felixrost.de |
STeve
macmandigital.com |
I tend do place the cursor into the gap and then press "L" to jump back and then SHIFT+TAB to select or vice versa (TAB and then SHIFT+L).
The reason: Sometimes there is a short fade out at the end of the region, so if you place the cursor into the region and hit TAB once, you're at the beginning of the fade out and not at the beginning of the gap Hope this helps Timothy PS: instead of "L" you can use OPTION-TAB -> SHIFT+OPTION+TAB = SHIFT+L |
Key command to de-select regions previous and next regions? | jkuehlin | Pro Tools 10 | 1 | 08-03-2013 06:52 AM |
What is the quickest way to split multiple regions at selection point? | jkuehlin | Pro Tools 10 | 1 | 07-24-2013 04:26 PM |
"Select Unused Regions" selects USED regions. Please help.. | pukeuv | Pro Tools TDM Systems (Mac) | 9 | 04-26-2007 02:04 PM |
select unused regions bug in PT7? | inkness | Pro Tools TDM Systems (Mac) | 0 | 12-11-2005 04:18 PM |
how to select multiple regions... | chris.d | Tips & Tricks | 2 | 01-23-2003 09:48 AM |
