Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 04-02-2011, 07:16 PM
DjStrike1 DjStrike1 is offline
Default Unable to install Pro Tools SE 8.0.3
Hello,
I am having issues installing the Pro Tools SE 8.0.3 that came with the M-Audio Fast Track interface. Once the installer starts it is immediately halted and I am given the error "error number 0x80040707
description DLL function call crashed ISRT._ctrlsethtmlcontent"(screenshot below) I have attempted to run the install in compatibility mode, safe mode and as administrator but the same error occurs. I also copied the disk to my hard drive but received the same error. My system specs are below. Any thoughts?
Computer
Model : System manufacturer System Product Name
Workgroup : WORKGROUP
Host Name : MurderedOut
User :
Processor
Model : AMD Phenom(tm) II X6 1100T Processor
Speed : 3.71GHz
Cores per Processor : 6 Unit(s)
Threads per Core : 1 Unit(s)
Type : Six-Core
Integrated Data Cache : 6x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size
L2 On-board Cache : 6x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size
L3 On-board Cache : 6MB, ECC, Synchronous, Write-Back, 48-way, 64 byte line size, 6 threads sharing
Computer
Mainboard : Asus M4A89GTD-PRO/USB3
BIOS : AMI 1703 11/16/2010
Bus(es) : ISA X-Bus PCI PCIe USB FireWire/1394
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : No
Total Memory : 8GB DIMM DDR3
Chipset
Model : AMD RS780/880 Host Bridge
Front Side Bus Speed : 2x 2GHz (4GHz)
Channels : 1
Memory Bus Speed : 2x 101MHz (202MHz)
Chipset
Model : AMD F10h Athlon 64/Opteron/Sempron HT Hub
Channels : 2
Memory Bus Speed : 2x 670MHz (1.34GHz)
Memory Module(s)
Memory Module : SanMax F3-10666CL9-4GBSR0 4GB DIMM PC5300U
Video System
Video Adapter : ATI Radeon HD 5700 Series (720 SM5.0 700MHz, 1GB DDR5 4.6GHz 128-bit, PCIe 2.00 x16)
Graphics Processor
Compute Shader Processor : ATI Radeon HD 5700 Series (720SP 700MHz, 1GB DDR5 4.6GHz 128-bit)
STREAM Processor : ATI Radeon HD 5700 Series (720SP 9C 870MHz, 1GB DDR5 4.6GHz 128-bit)
Storage Devices
Seagate ST31000524AS (1TB, SATA600, 3.5", 7200rpm) : 932GB (E:)
WDC WD1001FALS-00E3A0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (C:)
ASUS DRW-24B1ST a (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
DTSOFT BDROM () : N/A (F:)
Logical Storage Devices
New Volume (E:) : 932GB (NTFS) @ Seagate ST31000524AS (1TB, SATA600, 3.5", 7200rpm)
System Reserved : 100MB (NTFS)
Hard Disk (C:) : 931GB (NTFS) @ WDC WD1001FALS-00E3A0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache)
Optical Drive (D:) : N/A @ ASUS DRW-24B1ST a (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Optical Drive (F:) : N/A @ DTSOFT BDROM ()
Peripherals
LPC Hub Controller 1 : ATI (AMD) IXP SB600/700/800 SMBUS Controller
LPC Hub Controller 2 : ATI (AMD) SB700/800 LPC host controller
LPC Legacy Controller 1 : T2 87-21
Audio Device : ASUS IXP SB600 High Definition Audio Controller
Audio Codec : Realtek Semi High Definition Audio
Audio Device : Pine Technology EG JUNIPER XT Audio Device [Radeon HD 5700 Series]
Audio Codec : ATI (AMD) HDMI Audio
Serial Port(s) : 1
Disk Controller : ATI (AMD) SB700/800 SATA Controller [IDE mode]
Disk Controller : ATI (AMD) SB700/800 IDE
Disk Controller : ASUS JMB361 AHCI/IDE
USB Controller 1 : ATI (AMD) SB700/800 USB OHCI0 Controller
USB Controller 2 : ATI (AMD) SB700/800 USB EHCI Controller
USB Controller 3 : ATI (AMD) SB700/800 USB OHCI0 Controller
USB Controller 4 : ATI (AMD) SB700/800 USB EHCI Controller
USB Controller 5 : ATI (AMD) SB700/800 USB OHCI2 Controller
USB Controller 6 : ATI (AMD) SB700/800 USB OHCI0 Controller
USB Controller 7 : ATI (AMD) SB700/800 USB EHCI Controller
USB Controller 8 : ASUS uPD720200 USB 3.0 Controller
FireWire/1394 Controller 1 : ASUS VIA VT6308 1394 OHCI Controller
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Old 04-09-2011, 12:46 PM
Default Re: Unable to install Pro Tools SE 8.0.3
I was finally able to get Pro Tools to install. I had to reformat my drive and reinstall Windows 7 in order to get Pro Tools to work. The only problem with that is I had just installed Windows 7 the day that I had the issue with Pro Tools....
Unable to install Pro Tools MP9 on my new laptop DtothaK Pro Tools 9 6 03-07-2013 02:46 PM
Unable to install Cosmonaut Voice on Pro Tools 10 Zarabozo Windows 5 12-03-2012 01:48 PM
Unable to install pro tools brettcbowden 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-19-2011 07:21 PM
Unable to install pro tools se, min. requirements not met? schonn_two Pro Tools SE and Essential (Win) 0 04-28-2011 08:30 AM
Unable to Install Pro Tools 8 LE - I/O Device Error (Data2.cab) Morphine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-19-2009 06:02 PM
