Audio Input Monitoring
Hey all, is it possible to toggle Audio Input Monitoring in Pro Tools SE so I can practice playing along without actually recording? Thanks!
Re: Audio Input Monitoring
If you have the track "armed" for recording, it should send live audio through. Then all you have to do is press play (just don't hit the recording button next to the play button) and you should be able to jam along with the previous recordings.
But the disadvantage is, you lose the effects. I'm still not shure if there is a way around it, or if they purposely did that so you would have to buy the full version. You have the effects when you record, but if you just want to practice, it turns them off. It pisses me off too because I just run a straight line into the pre-amp, haha. That's what being cheap gets me I guess. |
Audio Input Monitoring Problem PT 10 | crazyjazzdrummer | Pro Tools 10 | 22 | 08-17-2013 02:51 PM |
Auto input/input only monitoring failing in PTLE 8.0.4 | miketeachesclass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-11-2012 08:48 AM |
Auto Input monitoring / Input only monitoring - Alt+K | AdamPT8 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-09-2010 10:50 AM |
DAE (Logic) Audio Input Monitoring | dreamgroove | Pro Tools TDM Systems (Mac) | 3 | 07-22-2008 07:30 AM |
Audio input monitoring button on C24 | tamtamstudio | ICON & C|24 | 0 | 11-23-2004 06:12 AM |
