triggering samples in reason from PT LE
I have PT LE 6.1 with rewire. I have reason 2.5. I am wanting to use drum midi tracks from PT to trigger drum kits or samples from either REX or either of the two samplers. I load a sample in the samler or the REX kit and then assign the midi on an auxillary track and then hit play and it should just trigger the sample, well it trys to play a default song in reason which I don't have setup and don't want to. Can you just trigger samples in Reason or do you have to program a song and that is the only thing that can be used in PT? Any insight will be helpful.
Thanks. |
Re: triggering samples in reason from PT LE
first of all, you can get rid of the default song by simply deleting all the instruments. secondly, you can create your own default song (template). its in the preferences on the first "page". my template consists of a mixer with reverb, delay and chorus sends. it's all set to go when i start adding instruments.
next, i'm not quite sure what you're getting at by your original question. your terminology is off... i think you're trying to do one of 2 things - either load loops or a midi drum kit. if its loops you're after, create a dr.rex player in reason, load your loop, then hit the "to track" button and it will dump the sequence to the reason sequencer for that track. then when you hit play in PT, it will play it in sync. you can adjust the sequence to taste. sometimes i load a few loops together and quantize the sequence. experiment. if you're trying to get midi drums going, create a redrum in reason, then load a kit. then in PT, create a midi track and set the input to your midi controller and the output to that redrum (it will show up in the list of midi outputs). then rec arm the track and you're all set. if you want to use the nn-xt sampler, do the same thing as above, but i don't think there are any drum kits for nn-xt. however, you can import soundfonts to nn-xt and there's tons of those floating around the internet. good luck...
i love my apple iPhone! |
How do I do this in pro tools? (triggering samples) | jaytonbye | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-31-2011 05:15 PM |
Kick is triggering multiple samples | zv yoda | The Drum Room | 6 | 01-08-2010 07:30 AM |
Midi Triggering Drum Samples | Kenny Gioia | Pro Tools TDM Systems (Mac) | 26 | 12-07-2008 07:01 PM |
Triggering drum samples with your hands. | EjA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-14-2002 10:30 PM |
Triggering samples on PC using midi? | stellaorguinness | Tips & Tricks | 0 | 10-09-2002 06:28 AM |
