The best time stretching app..
I’m just curious to know what everyone thinks is the best time stretching app for samples these days. I’ve noticed that there are big differences between the ones offered as standard with avid’. Serato Pitch 'n Time Used to be the one to beat. Is that still the best or are there less expensive options that do just as well?
Re: The best time stretching app..
The current Pitch 'n Time Pro would be my first choice. Zynaptiq Elastiq is next. Elastic Audio's X-Form is 3rd(and much better than the other algorithms), but it does take longer to render. Melodyne can do for small clips, but I wouldn't use it for something like changing the tempo of a song
I find that working with higher sample rates can slightly improve the quality. The more data you pass the algorithm the less it has t interpolate.
Anything that works offline is also bound to have improved quality over anything that works in real time. In theory. One way to make this work with you is to use a real time algorithm to experiment with and then run the same/similar settings on a copy of the original using an offline algorithm. It may still require tweaking, but it should cut down on the time required. |
When I kicked it up to 96k, Waves' good ol' Soundshifter sounded best.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
Pitch 'n Time here.
The two best sounding imo :
1) Avid x-form 2) Serato pitch'n time That said when doing more extreme 2 x time stretching none really cuts it or preserves the original material good enough imo. |
I have both Pitch n Time and X-Form. There is little to choose in quality, but the Serato PnT works way quicker. Select it as your TC/E plugin in preferences and it makes stretching audio a breeze.
Mac Mini M1 16 GB OS 12.7.4 PT 2024.3 |
This is pretty much what I see.
I’ve been using X-Form. If there’s not a huge difference in that and Serato, I probably will just stick with that and save my money. I do notice that the time stretch in Logic works quite well on certain things…and I think the way Logic integrates samples is much smoother than PT so at times I’ll build my track there and import it.
pt time stretching | geeball | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-09-2009 11:44 PM |
Time stretching... | Gemylon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-20-2008 01:50 PM |
Time Stretching | spaceman | Tips & Tricks | 21 | 04-16-2006 11:30 PM |
Time Stretching | FatBelly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-21-2006 01:55 PM |
Same bpm and Time Stretching | ecsmix | General Discussion | 0 | 10-15-2003 04:10 PM |
