Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 09-03-2021, 05:45 AM
Philthy Philthy is offline
Default Anyone running Carbon successfully on a Hackintosh?
Anyone? If you were successful, what motherboard works? I'm wondering about ethernet chips in particular, seems like it might matter. TIA
Phil Mann
Silk City Music Factory - CT Recording Studio
Old 09-03-2021, 07:27 AM
dominicperry dominicperry is online now
Default Re: Anyone running Carbon successfully on a Hackintosh?
I'm not guaranteeing this will work with AVB - but the claim is that this is the same chip. https://www.youtube.com/watch?v=aq9TTsgGWQE
I can't find anyone else who's got AVB working with a Hackintosh.
I can confirm my Mac Pro 7.1 shows "Apple AQC107-AFW" as the Ethernet card, which is the same model number (without the word 'Aquantia') as the one shown in the video. The kext does include the word 'Aquantia', so it's safe to assume this is the same card.
Dominic
Old 09-03-2021, 07:41 AM
Dominic
Thanks for the information. Just to be clear, you're not reporting any failure to get it working, just that you don't know of anyone who tried?
Phil Mann
Old 09-03-2021, 08:19 AM
Correct - I just did a search and read some stuff. I'm not a Hack user myself nor do I know any personally.
I'm interested in AVB because I have a Carbon, and I find that there's very little information out there from Apple or anyone else about AVB in general.
I've been looking at Ethernet adaptors with a view to connecting the Carbon to an M1 Mac (either an MBAir or one of the upcoming, larger MBPros) which don't have Ethernet ports, and it's interesting and worrying that lots of Ethernet docks don't seem to support AVB. And once again, there's very little information about it. For example, the Caldigit TS3+ which is a well regarded multi-port hub with an Ethernet port, doesn't mention AVB, and I can't find a single reference to anyone even trying it. Caldigit's new 10G Ethernet adaptor DOES support AVB (which makes me assume the TS3+ does NOT) but even the 10G adaptor has absolutely no information available regarding AVB, other than that it supports it.
Old 09-06-2021, 12:26 AM
ilmalvaggio ilmalvaggio is offline
Runs smoothly here on Thunderbolt 3 with Apple USB-C to TB2 + TB2 to Ethernet Adapters.
Old 09-06-2021, 02:07 AM
So the original question was - what motherboard do you have that works?
Old 09-06-2021, 02:20 AM
Gigabyte Z490 Vision D but Ethernet ports do not work with Carbon. Only adapters on usb-c
Old 09-06-2021, 02:26 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is online now
I must run my SoundGrid interface with a USB3 to Ethernet adaptor because of incompatibility with Intel's Ethernet chips.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 09-07-2021, 04:43 AM
martthie_08 martthie_08 is offline
I tried with the Sonnet Solo 10G card,
Carbon shows up but disconnects after about a minute till the next reboot and I gave up on it (normal ethernet worked fine though).
This is on a Gigabyte z390 gaming x motherboard, both Catalina and Big Sur.
Will probably try installing a Titan Ridge Thunderbolt card next.
Old 09-17-2021, 05:02 PM
andre.st.denis andre.st.denis is offline
You can use Carbon with your normal Ethernet ports but it disconnects with the Sonnet Solo 10G PCIe card? I have the Gigabyte Z490 Vision D and I was thinking of getting that card but will probably hold off if that's the case. Did the Thunderbolt card work for you?
Is anyone running Apollo with Thunderbolt on Hackintosh? Melodeath macOS 7 10-17-2017 09:09 PM
Who is Running PT 11 HD Native successfully K Roche Pro Tools HDX & HD Native Systems (Mac) 17 09-27-2013 12:02 PM
Is any one running i7 970 successfully with PT9? Violet Windows 2 05-11-2011 05:00 PM
Is anyone running 5.1 on OS8.6 successfully? marc@soundpost Tips & Tricks 7 06-26-2001 03:51 PM
