Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-10-2020, 02:51 PM
Hardin Hardin is offline
Default Need Preference for Folder Track Orientation
Greetings everyone!
I believe this to be fairly simple. If I'm missing this, please let me know. I don't know how others react to this.
If I have an Aux as a submaster/subgroup track, it is normally at the right end of the track section. When I make this a routing Folder Track, it is then at the left end of the track section. This is really throwing off my mix orientation as I'm working through a session.
This is actually really confusing because your subgroups swap position to the left of the tracks when made into routing folders.
Can there please be a Mix Preference which allows the user to set the Folder track orientation to "Right" or "Left" or something similar? Otherwise, I don't think I'm going to use routing folders anymore. bummer...
Blessings,
Ryan
Gadgets can make the music better, but the pursuit of gadgets is killing music.
Old 04-10-2020, 09:03 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default Re: Need Preference for Folder Track Orientation
Originally Posted by Hardin View Post
Greetings everyone!
Blessings,
Ryan
I also usually have my auxes to the right, but I've adapted to the new arrangement. Maybe there should be a preference or at least the ability to move it over to the right if you want to.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 04-19-2020, 06:17 AM
zakkwylde13 zakkwylde13 is offline
Yes, this is very weird! Aux's are to the right, of course! And we need to be able to change this, ASAP, please!
Old 04-19-2020, 07:33 AM
DontLetMeDrown DontLetMeDrown is offline
Agree. Having the folder at the bottom (edit view) or right (mix view) seems more logical.
Old 04-19-2020, 07:35 AM
JFreak's Avatar
JFreak JFreak is offline
Just the same where it is on edit window, but I'd surely like to see it on right of tracks on mix window
Janne
Old 04-19-2020, 12:55 PM
clutch clutch is offline
This is doing my head in too! A preference option would be great.
He used to cut the grass...he was a very nice boy...
Old 04-19-2020, 01:44 PM
Andre Knecht Andre Knecht is offline
+1
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 04-19-2020, 01:56 PM
Oggy Oggy is offline
+1
Old 04-20-2020, 02:57 AM
midnightrambler midnightrambler is offline
Yeah, as soon as I saw the "aux" routing folder on the left, instead of the right, I stopped using them. I thought it was just me being intractable!
Also, why isn't there a fader of some kind on "basic" folder to control everything in that folder? Like a "mini VCA" maybe. There's already effectively a control group for "mute" and "solo" on those folders. Seems such a waste of space.
Old 05-13-2020, 06:38 PM
kelsey's Avatar
kelsey kelsey is offline
For me the hierarchical nature of folders took some getting used to. Now instead of viewing my session as sources that build into a final product, I view the session as a final product that branches out into it's sub parts. I honestly find it more organized this way and easier to navigate. I got used to working this way with Reaper.
I still think an option to have folders expand above and to the left would be great, and would make the transition to using them smoother.
https://wanderingear.net
Avid preference folder missing in High Sierra (10.13.2) GuitarGuy92 macOS 2 01-09-2018 04:54 PM
So where is this iTunes library folder preference? EricWillhelm macOS 0 10-21-2011 08:10 PM
Missing audio in mac/preference/sound folder! dirrgoldenschlaggwer Pro Tools TDM Systems (Mac) 0 12-28-2010 09:34 AM
5.1 Audio Track Layout Preference Rick Sanchez Post - Surround - Video 3 12-03-2010 06:06 PM
Where's the Preference Folder? teacherman Pro Tools TDM Systems (Mac) 2 08-14-2007 11:45 AM
