Old 05-11-2017, 06:22 PM
SigFriedChicken's Avatar
SigFriedChicken SigFriedChicken is offline
Default Quick way to identify record-enabled tracks?
Is there a quick way to identify all currently record-enabled tracks?
I know I can just manually scan through the tracks, but this isn't as easy when you have a large number of tracks. I'm tired of discovering that I've been accidentally recording over additional tracks when I thought I only had one track enabled.
I suppose I could uncheck record-enable for the current track, and watch to see if the "Track Record Enabled" warning light is still one. Is that how people generally do it?
Old 05-11-2017, 07:27 PM
PMF Media PMF Media is offline
Default Re: Quick way to identify record-enabled tracks?
Really, I think your best bet is to just position all the record enabled tracks together on the screen so that the flashing "R" can be easily seen, the quickest way to enable/disable record on a group of tracks is run the cursor down all of them and hit "Shift +R"
Old 05-11-2017, 08:29 PM
sw rec sw rec is offline
On the mix window, the faders turn red.
Old 05-11-2017, 10:24 PM
Ed Douglas's Avatar
Ed Douglas Ed Douglas is offline
I wish there was a similar indicator like the solo and mute status icons in the Edit window toolbar. I'd also like to see a global track armed indicator in the PT Control app - I miss that feature from the old Control 24.
E>
Neotech Concepts
http://www.imdb.com/name/nm0235036/
! sonic gymnastics for the illusionary arts !
2022 Mac Studio Max 64GB / 1TB, macOSX 13.6.6, 2019 i9 MacBook Pro (15,3), macOSX 14.4.1, PT Ulti 2024.3.0, DAR 5.1, MDA Creator1.5, Rx10 Advanced, Ozone 10 Advanced, Kontakt 7, Soundminer v6.1Pro, Spanner 4, PaulXStretch,
EuControl 2023.11.0, Avid Control 2023.11.0, Avid S1, iPad Pros 12.9" gen 3 & gen 4, Apollo 8 Duo, UAD-2 Satellite Quad, Glyph 2TB tb3 NVMe SSD, x2 Glyph 2TB SSDs, x1 Glyph 4TB SSD, OWC tb3 Dock, OWC Thunderbay 8 62TB
Old 05-13-2017, 06:03 AM
john1192 john1192 is offline
E>
there is a RED light NExt to the REcord Button on the transport ..
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 05-13-2017, 12:30 PM
Andre Knecht Andre Knecht is offline
Here are two easy and quick options:
1 - Disable ”Latch Record Enable buttons“ [Preferences/Operation]
When disabled, clicking on any track‘s Record button will automatically disarm any such button currently armed on any other tracks.
If you prefer to keep the latching behavior enabled…
2 - Option-click any Record button twice.
This will arm and then disarm all tracks at once, leaving you with a clean slate from which to select only what’s needed next.
IHTH,
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 05-14-2017, 10:07 AM
Good ideas. Thanks, all!
Old 05-14-2017, 05:20 PM
K Roche's Avatar
K Roche K Roche is offline
Just option/alt click on any track record button they will all arm or disarm (note ) if it is an audio track only all audio tracks follow and if it is an instrument track only instrument tracks will, so if you have both you will have to do one of each. But if you have tracks not on screen it is a pretty quick method
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 05-14-2017, 10:39 PM
SomeOtherGuy SomeOtherGuy is offline
IHTH,
Disabling latch only works with audio tracks. It doesn't work if you have a MIDI track accidentally still record-enabled when you record-enable a new audio track. I can't tell you how many MIDI tracks I've accidentally erased over the years. This behavior needs to be fixed by Avid. No excuse for this.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
Old 05-15-2017, 12:11 AM
Extreme Mixing Extreme Mixing is offline
The best method I've found is to option click on any record enabled track. That will cancel record on all other tracks. Then you know nothing can be in record. Why would you need to see them if you know you want all of them out of record? That's what got you into trouble in the first place! You thought you knew what was going on, but you didn't!
Steve Shepherd
Extreme Mixing
No output on Record Enabled Tracks Headlow Pro Tools 11 2 07-24-2013 10:32 AM
Automation on record enabled tracks crazyfoo' 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-03-2004 05:50 PM
HELP! - Pops and clicks on record-enabled tracks Spitshine-Drums 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 02-18-2004 10:20 PM
Reverb on record enabled tracks jaceever Tips & Tricks 2 07-25-2002 01:22 PM
Automation on record enabled tracks Klaus Badelt Pro Tools TDM Systems (Mac) 0 01-19-2000 02:22 PM
