VU meter question
Hi guys !
Currently im using the klanghelm VU meter for... well you know ! . The thing is that in Protools 12 it runs like it should be . Right of the bat the Master Fader in PT12 display -18dbfs when my signal on the VU meter is around 0dbvu thats good . But in Protools 10 its another story . With a singal runing about 0dbvu on the VU meter and less than that, the Protools meter shows the same meassure but in dbfs :-/.. in both cases the vu meter is set to display -18dbvu . Ive tried to find a meter change option but i dont think PT10 have it like PT12 . Maybe is a little thing and i cant see it ..can somebody help me see whats wrong ? Thanks !
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Re: VU meter question
Yeah, 10 doesn't have any meter options like 12. But, 0dBvu should still show as -18db in 10. Maybe a bug with the plugin.
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
Hi and thanks !
The thing is that with unprocessed kick the meter works as suppoused to be but after processing it with eq etc. I noticed this behavior .
Make sure you have Pro Tools set to Post Fader Metering. This will show the audio metered after your plugins and after the fader movement. If you have it on pre-fader metering, it will meter the actual audio file before going through the channel. And leave your fader at 0 while doing the test.
Actually, the levels displayed while in Pre-fader metering mode are post-inserts, which is crucial in maintaining gain structure. To visualize audio files levels one needs to bypass any plugins found on the channel.
IHTH.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
Hi guys !
Actually i think im in post-fader mode but im gonna double check that this night and let you know .. thanks again !
Hi guys !
Level Meter Question | JCWarrior | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-09-2007 07:07 AM |
CPU meter question | Cliffy_Boy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 11-26-2004 02:20 PM |
VU meter question | viaspiaggia | Post - Surround - Video | 4 | 05-20-2004 08:51 AM |
Bus Output Meter Question... | tomhartman | ICON & C|24 | 1 | 06-22-2001 12:43 AM |
Meter question | Craiggo | Pro Tools TDM Systems (Mac) | 2 | 02-16-2001 07:01 PM |
