Old 07-12-2010, 09:20 PM
relaxxx relaxxx is offline
Default Digidesign 192 Digital IO
Hey,
This is gonna sound like the dumbest question to most of you, so if you're going to write comments like 'dont bother' save your breath for someone who is actually going to respond nicely.
I have just bought a Digidesign 192 Digital off a friend of a friend. It came with no cables and I already have an HD3 old PCI set up but with a 96.
Unfortunately I have been out of the game for a while, and I just want to know if you are able to use the 192 with analog equipment - be it with the right cable or whatever. If not then Ill sell it. I have no manuals and I have been trying to find out online but I cant find anything so if someone can help me out that would be great.
Cheers
Old 07-12-2010, 10:40 PM
Sean Russell Sean Russell is offline
Default Re: Digidesign 192 Digital IO
Originally Posted by relaxxx View Post
Hey,
Cheers
If I read correctly, you want to plug analog gear into a 192-D? The short answer is 'no'. Unless you are feeding digital signal from other sources, that sucker won't help. If you are feeding from a digital console or whatever, you just need a digilink cable to piggyback from the 96 (although, depending on the setup, I'd make the 192 the primary interface).
HTH
... but does it help the chorus?
Old 07-12-2010, 11:02 PM
formfunction formfunction is offline
Cheers
http://www.avid.com/US/products/192-Digital-IO
Old 07-12-2010, 11:21 PM
thanks heaps for the quick responses..
its probably no use to me as I dont have a digital mixer.
so there is no cable or anything I can buy that allows inputs for analogue gear - eg. juno, etc..
cheers
Old 07-13-2010, 02:39 AM
Buccanears's Avatar
Buccanears Buccanears is offline
You're in Oz. Get in touch.
Q "where are your buccanears?"
A "on your buccanhead!"
IMDB
Old 07-13-2010, 05:09 AM
audiobob's Avatar
audiobob audiobob is offline
cheers
no..a digital mixer will provide the analog to digital / digital to analog conversion you need to use the interface. cables on their own will not provide this conversion.
Old 07-13-2010, 09:14 AM
Craig F Craig F is offline
cheers
there are mic pres with digital out there are recorders with digital in
think about what of those you may want to add in the future that you will need I/O that the 96 doesn't have
Thank you,
Craig
Digidesign Digital 192 I/O internal 50 pin cables Alex Casey Pro Tools HDX & HD Native Systems (Mac) 28 11-07-2013 06:42 AM
Digidesign 192 Digital i/o Interface SolidSoundSweden Buy & Sell 0 08-23-2013 02:01 AM
Digidesign 192 Digital interface Guy McDude Buy & Sell 0 04-14-2013 06:52 PM
digidesign 192 digital and digidesign pre connection help benhurk Pro Tools TDM Systems (Mac) 5 03-20-2009 07:46 PM
Digidesign Old ADAT Digital Interface?? andrej770 Pro Tools TDM Systems (Mac) 2 12-16-2001 03:27 PM
