Old 05-27-2010, 07:36 AM
Dism Dism is offline
Default Access violation during auto-save
Hey all,
Having some issues with my XPsp3 PC at work, that seem to have appeared just this week. Updated to 8.0.3cs2, deleted databases, prefs, etc. Ran Windows Update and got all of the latest .NET framework updates, security updates... everything. IE still at 6.
Still can't seem to sus out the problem... but it seems to happen in my MIDI heavy sessions, but it doesn't seem to be exclusive to any particular plugin. so I've included a Sandra and a screenshot of the proposed error. Any suggestions are welcome!
http://img41.imageshack.us/img41/1710/errorfda.jpg
Btw, all drives are definitely set to Write.
SiSoftware Sandra
Computer
Model : Gigabyte GA-MA780G-UD3H
Workgroup : WORKGROUP
Host Name : Mario
User : Dan
Processor
Model : AMD Phenom(tm) II X4 945 Processor
Speed : 3GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 1 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size
L2 On-board Cache : 4x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size
L3 On-board Cache : 6MB, ECC, Synchronous, Write-Back, 48-way, 64 byte line size, 4 threads sharing
Computer
Mainboard : Gigabyte GA-MA780G-UD3H
BIOS : Award (Phoenix) F4 08/12/2009
Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 2.75GB DIMM DDR2
Chipset
Model : AMD RS780 Host Bridge
Front Side Bus Speed : 2x 2GHz (4GHz)
Shared Memory : 512MB
Memory Bus Speed : 2x 101MHz (202MHz)
Chipset
Model : AMD F10h Athlon 64/Opteron/Sempron HT Hub
Total Memory : 4GB DIMM DDR2
Memory Bus Speed : 2x 536MHz (1GHz)
Memory Module(s)
Memory Module : Micron 16HTF25664AY-1GAE1 2GB DIMM DDR2 PC2-8900U DDR2-1112 (5-7-7-25 4-32-8-4)
Video System
Video Adapter : ATI Radeon HD 3200 Graphics (40 SP, 512MB, Integrated Graphics)
Storage Devices
WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 466GB (C:) (E:)
WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 466GB (D:) (F:)
HL-DT-ST DVDRAM GH22NS50 (ATAPI, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:)
Logical Storage Devices
Hard Disk (C:) : 100GB (NTFS) @ WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache)
Sessions (E:) : 355GB (NTFS) @ WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache)
Library (D:) : 456GB (NTFS) @ WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache)
BACK UP (F:) : 10GB (FAT32) @ WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache)
Optical Drive (G:) : N/A @ HL-DT-ST DVDRAM GH22NS50 (ATAPI, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Giga-Byte IXP SB600 SMBUS Controller
LPC Hub Controller 2 : ATI (AMD) SB700 LPC host controller
LPC Legacy Controller 1 : ITE IT8718F
Audio Device : Giga-Byte IXP SB600 High Definition Audio Controller
Audio Codec : Realtek Semiconductor Realtek 885 High Definition Audio
Audio Device : Giga-Byte RS780 Azalia controller
Audio Codec : ATI (AMD) 791Ah
Disk Controller : Giga-Byte SB700 SATA Controller [IDE mode]
Disk Controller : Giga-Byte SB700 IDE
USB Controller 1 : Giga-Byte SB700 USB OHCI0 Controller
USB Controller 2 : Giga-Byte SB700 USB OHCI1 Controller
USB Controller 3 : Giga-Byte SB700 USB EHCI Controller
USB Controller 4 : Giga-Byte SB700 USB OHCI0 Controller
USB Controller 5 : Giga-Byte SB700 USB OHCI1 Controller
USB Controller 6 : Giga-Byte SB700 USB EHCI Controller
USB Controller 7 : Giga-Byte SB700 USB OHCI2 Controller
FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller
SMBus/i2c Controller 1 : ATI SB600 SMBus
SMBus/i2c Controller 2 : ATI AFS SMBus
Printers and Faxes
Printer : Send To Microsoft OneNote Driver (300x300, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : Canon iR9070 PCL6 (600x600)
Printer : Lexmark Optra S 2450 PS (600x600)
Network Services
Network Adapter : Realtek RTL8168C(P)/8111C(P) PCI-E Gigabit Ethernet NIC - Packet Scheduler Miniport (Ethernet, 1Gbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3)
Platform Compliance : x86
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 05-27-2010, 08:52 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: Access violation during auto-save
Good Mornz Dtism...
That is mainly due to ram getting jammed up from the VI's etc.
I've had that happen a few times even in 7.4 so it isn't relevant any to 8 @ all...
So definitely with 2.75g some memory is gettin hosed with lots of Midi going on because not only the VI's eat the ram, but midi info itself does jus as well...
plus I see u have ur OS drive partitioned with the sessions on it; U kno that is the same as the OS drive still rite?
Get me,,,,Get me though
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 05-27-2010, 09:19 AM
Originally Posted by Keybeeetsss View Post
Good Mornz Dtism...
Sunofa.... I did not even notice that before!
I didn't partition these drives, they came this way when I started here. Man, the guy who I replaced REALLY didn't know what he was doing...
I fresh formatted the C drive on my first day, but I totally never noticed the session partition was on the same drive. Guess it's time for some disk management.
I'm gonna talk to my tech guy, see if I can order a 3rd drive for my sessions.
Btw: is there a way to access the rest of my RAM that XP clearly isn't seeing without upgrading the OS?
D
Old 05-27-2010, 09:43 AM
Well I don't kno how the 3g/ switch works being u comp is only seeing 2.75;I'm thinkin u could do the /userva switch instead... Have u ever done that on this rig?
LOOK jus in case u need to...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 05-27-2010, 09:57 AM
Haven't done much with this computer yet, only been working here for about a month and a half.
Everything was going well for a while, I only started running into these errors in the last week. Did every possible Windows update I could find today, and it seems to be a bit more stable. Currently migrating my files between partitions to see if that helps a bit, too. Gonna get a 3rd drive hopefully today, but not counting on it.
I'll try doing some memory optimizations if I get some time.
Thanks again, Keymaster!
D
Old 05-27-2010, 10:07 AM
That sometimes can be a no-no but I guess if its online, then u hav to let it do as it does; I hadn't updated my comp(PT rig) in well over a yr & its great
But, nevertheless, Ur welcome Dtism
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 05-27-2010, 11:47 AM
Did the 3GB switcherooo, switched the partitions around and everything is running a whole lot smoother with no crashes as of yet!
...it does remind me why I have a Mac at home though.
But after a bit of tweaking, everything seems to be rockin'!
If ever we meet, you are indebted to plenty o' Fruit Snax!
D
Old 05-27-2010, 11:54 AM
U will kno I will gradly accept
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 05-27-2010, 02:07 PM
TOM@METRO's Avatar
And.. they are now "dentist approved".
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.12 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 05-27-2010, 03:14 PM
All the more better
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
auto tune evo tutorials cause access violation paulreed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-08-2011 12:59 PM
PT LE 8 cs2 - periodic auto backup access violation David Lang 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-04-2009 08:34 AM
Access Violation when trying to save kevinb511 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-03-2007 11:31 AM
access violation--won't save-wouldn't shut down michaelo japan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-18-2006 06:26 PM
access violation errors on auto save. dawkab Pro Tools TDM Systems (Win) 3 03-20-2006 09:58 AM
