Unsteady Mac
System Mac G4 400mhz OS 9, digi 001 PT 5.1, waves native gold bundle.
Last couple of times i've tried to boot pro-tools the mac seems to be taking longer than it used too and infact it has locked up on more than one occasion. Got a 'bad memory' message 'contact you service tech' during one boot up but the system seems to work ok after that. One of my waves reverbs has gone walkabout as well which is slightly disturbing. Also i tried to load another reverb plug during a session and the mac locked again. The system has run flawlessly for well over three years so this is a little scary. Any guidance as to what action i should take would be greatly appreciated as i get the feeling this is the calm before the storm. Thanks in advance. Ian
ianbenn |
Re: Unsteady Mac
Seems pretty clear. Get a utility to test the ram modules, find the bad module, get new module(s).
dk
www.dpksound.com |
Re: Unsteady Mac
Thanks DK, please bear with me...
Is there a utility disk i can load into the mac to check the system, or will i have to remove the ram memory and take it to a technician? Thanks.
ianbenn |
Re: Unsteady Mac
I seem to remember there was a way to check the ram in OS9 (have not used OS9 in a long time though), it had something to do with the memory control panel but that's all I remember.
A program like Tech Tool Pro will do memory tests also. Try the Apple support user forums and see if someone can point you in the right direction. You don't have to remove the ram to test it though. Good luck. dk
www.dpksound.com |
Re: Unsteady Mac
Loaded another 256 meg of ram and i'm up and running again. (Cheers dk)
I dont have a diagnostic disk though so i cant tell which of the 3 already installed 128 meg ram sticks is faulty. Anyone any ideas how to test, i would be grateful.
ianbenn |
Re: Unsteady Mac
Unsteady Metronome Solved.... | beerosaurus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-20-2013 09:29 AM |
unsteady clock and meter performance... | PLAbass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-09-2007 12:43 PM |
Midi click unsteady | harpdog123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-30-2001 10:39 PM |
Unsteady drummers | FK | Tips & Tricks | 14 | 06-23-2001 11:02 PM |
