Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 12-05-2013, 10:54 AM
Pat H Pat H is offline
Default 2 X accel PCI-X boards issue
Got an old Protools 7.4 on an HP xw8400
It has the core card and 1 Accel card and all works well.
Have picked up a second accel card and flex cable and tried dropping that in the bottom PCI-x slot.
Configure info indicates that the bottom PCI-x slot can be used optionally for an accel card.
The card and flex cable are good because if I swap them with my current accel card and cable it all works fine.
But when I add the second accel card and connect the flex cable launching Protools generates a DAE -1128 error and the next message warns of an incorrectly connected flex TDM cable. Then Protools quits.
Any thoughts anyone?
Can I add a second Accel card in that setup?
Old 12-05-2013, 11:00 AM
Craig F Craig F is offline
Default Re: 2 X accel PCI-X boards issue
should work
a) a Sandra Reports might show something
b) check the BIOS, see if that PCI slot has an odd setting applied to it
Thank you,
Craig
Old 12-05-2013, 11:13 AM
BIOS shows both slots as the same and at default settings.
I have a second xw8400 dual quad core (my ProTools is a dual dual core) so I may clone the HDD and try that crate as a test.
Device manager shows both cards and the core card and of course tried to install drivers on initial power up but couldn't.
But the working setup shows the same device !
Old 12-05-2013, 09:17 PM
Brandonx1 Brandonx1 is offline
What's digits at say?
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Helping a school with TDM PCIe Accel boards George Massenburg Pro Tools TDM Systems (Mac) 5 01-20-2014 06:46 PM
PT10.3, HD2 accel Avid I/0 Hardware insert issue? mattpgtr macOS 0 10-20-2012 10:52 AM
HD 3 Accel PCIe = 2 Accel Core + 1 HD Accel???? Eduardo Apolonia Pro Tools TDM Systems (Mac) 24 08-04-2007 02:20 PM
Runing Accel plugs on the "Accel PCIe core DaveSB Pro Tools TDM Systems (Mac) 0 12-19-2005 10:25 PM
G4/accel compatability issue? Krecording Pro Tools TDM Systems (Mac) 3 01-12-2005 05:59 AM
