Old 10-28-2016, 11:25 AM
Hitsoundtech Hitsoundtech is offline
Default TL Space AVID Profile Question
Dear All,
I did want to give a try to the TL Space on an Avid Profile console, and so I did install it on it. everything vent ok, but I had to purchase a 7 day trial period in order to give it a try.
I did drag and drop the activation to my iLok 2 on my PC, and then did plug this iLok back to the Profile.
Despite all my trials, the Profile still writes, my authorisation is expired...
Could someone help me figure out, what should I do to use this plugin?
Thanks,
Tamas
Old 10-31-2016, 02:25 AM
Default Re: TL Space AVID Profile Question
This issue was solved. avid Support did help me out.
I also want to say a thanks you here.
Anyway, now I am in trouble kn an S6L.
I dont know which version of "Space" plugin i need to install on it.
The V12 win installer did not work...
Thanks,
Tamas
Old 10-31-2016, 04:26 AM
Valentyn Valentyn is offline
Per my information Space won't work on S3L/S6L.
In general, for S3L and S6L you need Windows versions of AAX DSP 64 plug-ins.
So, if the plug-in doesn't have a dedicated VENUE installer:
1. Choose Windows AAX DSP 64 plug-in and download its PT installer.
2. Install it on some Windows machine.
3. Grab a plug-in from C:\Program Files\Common Files\Avid\Audio\Plug-Ins. Plug-in is a folder named like "<plugin name>.aaxplugin"
4. Put this folder into <your flash drive>\AAX Plug-Ins\
5. Install on Venue as usual.
If you don't have a Windows system around, then you can exit to desktop on VENUE and use that PT installer directly. Then you'll still need to use Options->Plug-Ins to actually VENUE-install the plug-in.
Old 10-31-2016, 05:15 AM
Kristo Kotkas Kristo Kotkas is offline
Tamas, I would kindly suggest you to use caution with Space on Profile. The only plugin that I have managed to completely crash the desk has been Space.
Old 10-31-2016, 05:28 AM
Thanks for the very important info!
Which high quelity (possibly convolution type?) reverb would you suggest me to use on S6L for symphonic orchestra?
And for Jazz?
Because for rock&roll or Pop, I think the 3 default reverbs ar kind of ok
Thanks,
Tamas
Old 10-31-2016, 05:56 AM
Dear Kristo,
I it still the case also with the S6L??
Thanks,
Tamas
Old 10-31-2016, 05:58 AM
It is on the list of compatible plug-ins....
so If it does not work, then you should remove it from the compatible plug-ins list
Thanks,
Tamas
Old 10-31-2016, 09:50 AM
RyanJ's Avatar
RyanJ RyanJ is offline
it shouldn't be on the list of compatible plugins. I'll have it removed. The web team sometimes gets these things wrong, but in general:
If a plug-in does not have a VENUE installer, then it definitely has NOT passed testing on VENUE.
Ryan John
Principal Product Manager | Avid Live Sound
[email protected]
Old 10-31-2016, 10:12 AM
Thanks Ryan for make this clear!
Any suggestion for a highquality reverb plugin available on S6L??
Thanks,
Tamas
Old 10-31-2016, 10:20 AM
RyanJ's Avatar
by FAR my favorite is the Sonnox Verb, that thing at 96k, is honestly amazing...
https://www.sonnox.com/plugin/oxford-reverb
Ryan John
[email protected]
Avid venue profile schematic Artstudio VENUE Live Sound Systems 2 04-04-2016 08:50 PM
Avid Profile Fader Bay Circuit Boards failing [email protected] VENUE Live Sound Systems 1 12-13-2015 11:07 PM
Updating from TL Space/Music Production ToolkitII to Avid Space Sadie Tango Pro Tools 11 4 02-08-2015 02:29 PM
FS: Digidesign / AVID Profile system in EU Kristo Kotkas Buy & Sell 0 08-28-2014 11:32 AM
Avid Profile Lock Screen Image Removal. fchef25 VENUE Live Sound Systems 11 05-22-2014 08:09 AM
