Old 02-25-2014, 03:34 PM
Fernando Ulibarri Fernando Ulibarri is offline
Default HD Native and HDX Latency on other DAWs
Hi guys,
New to the forum. Hope to get some info on the latency of HDX in other DAWs besides Pro Tools. (as far as tracking goes)
Latency for an Apogee running with a Thunderbridge is listed as 1.8 millisecons.
Latency for PT Native is listed as 1.7 milliseconds.
Latency for HDX is listed ad 0.7 milliseconds.
In the case of the Apogee, I'm assuming that number is not dependent on the DAW being used.
However, in case of the PT Hardware, does anyone know if those numbers change when using a different DAW other than Pro Tools? For example using an HDX rig with Logic X, or HD Native rig with Logic X. Still 0.7 ms and 1.7 ms? (using Core Audio drivers, I'm assuming)
Also, does anyone know how the latency is affected (if at all) when running the Apogee in PT HD mode, with an HDX card, both in Pro Tools and other DAWs? So for example using PT11HD with an Apogee Symphony in HD mode with an HDX card, would that still be 0.7 ms of latency? And how about using Logic X with the same setup, still 0.7 ms?
(Btw, I say Logic X, but in reality it could be any other DAW that is running Core Audio Drivers)
Thanks in advance!
Can't lower the buffer size for HD Native & Omni with 3rd party DAWs? akhafaji Pro Tools HDX & HD Native Systems (Win) 3 05-27-2014 05:24 AM
PT HD Native & HDX / latency? kirkbross Pro Tools HDX & HD Native Systems (Mac) 13 08-24-2013 09:48 AM
HD NATIVE vs HD TDM latency James Drake Pro Tools 10 20 06-19-2012 04:27 PM
omni/native latency vs mbox pro latency chrisdee Pro Tools HDX & HD Native Systems (Win) 34 03-30-2012 07:24 AM
PT7 is much slower than other native DAWS? don c 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-15-2006 05:56 AM
