Old 12-22-2005, 02:43 PM
WaDa TanK WaDa TanK is offline
Default Post Fader Meters
I can't seem to figure this out. I'm trying to set my track meters to Post fader, to visually monitor track volume, but can't remember how. I believe I was able to in 6.9 (running 7.0cs1) but I don't know (remember) if that was in another app or PT.
Thanks a Mill
Old 12-23-2005, 05:37 AM
Kevin Stone Kevin Stone is offline
Default Re: Post Fader Meters
From the PT Reference Manual (hint, hint)
Pre- and Post-Fader Metering
You can globally set audio track level meters to
indicate pre-or post-fader levels by selecting or
de-selecting Operations > Pre-Fader Metering.
When pre-fader metering is selected, the level
meters show levels independent of fader position.
With post-fader metering, the level meters
respond to fader position.
That's for 6.x, don't know if it changed in 7.
Old 12-23-2005, 06:58 AM
Yeah I know that's my bad, when I first selected it, it was just something I found while play'n around in the Program. And usually the only time I look in the Reference manual is when I'm doing a fresh PT install setting the Digi recommended optimizations.
But thanks I am checking the PT7 Reference now, cause I was looking in my ProTools visual quick start book, it mentioned what it was but not how to set it.
But again Thanks a MILL.
DeWALT
Old 12-23-2005, 10:25 AM
JMS40 JMS40 is offline
You should absolutely buy or print a hard copy of the Reference Manual... keep it in the magazine rack next to the toilet.
Old 07-29-2006, 07:20 PM
Harvey S. Harvey S. is offline
I know that is what the ref. man. says but my system seems to not respond. In other words, it appears to be stuck in pre-fader metering. Does my system have a bug or is there some operator sequence I am missing? Help!
Windows XP Pro, Digi001, PTLE 6.4, Command/8
Master Fader Meters ZoDMeister 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-04-2009 06:26 PM
revibe and pre post meters odeu87 Pro Tools TDM Systems (Win) 0 12-30-2008 07:48 PM
Mix window meters = pre fader. crsuribe Pro Tools M-Powered (Win) 3 04-29-2008 12:01 PM
Opinions on meters for post please.... Toe Jam Post - Surround - Video 30 12-31-2004 06:17 PM
Mono-Stereo Plug-In Bug with Fader Meters ?!... SimpleNatureSpirit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-06-2004 06:57 PM
