Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 12 Discussion
Old 07-17-2017, 04:04 AM
alexorta alexorta is offline
Default I/O Problem
Hello,
I have a problem with my Apollo uad quad and my PT 12.
My mic is coming in the 3rd pre-amp, i see it in vu-meter of "console" (application for this apollo), i can hear that, it's ok in 3rd.
My input patch is clean, 1 in 1, 2 in 2...
But when I want to record in PT, it is coming in "line 5" which is habitually the line input. I try to exchange input from the bottom of the apollo and.. when i put my mic in 1, in PT is coming in mic 3... Like if the patch do +2 in input..
Did you have ever seen this problem ? It's the first time i have this.
I try to check with other daw, I dont have the problem..
Thanks,
Alexis
Old 07-17-2017, 04:13 AM
ChuckS ChuckS is offline
Default Re: I/O Problem
Do you have the aggregate device selected for the Playback Engine in Setup? Also, UAD has a Pro Tools mode, but I believe you only need to use that if using hardware inserts.
PT 12.8.0 DP 9.13 VEP 6.x Komplete Audio6 HP ProBook 4730s i7 Quad Win10 (x64)
PT 12.8.0 DP 9.13 VEP 6.x 828mkII ADA8200 MTP-AV 2011 Mac Mini i7 Quad Sierra.5
Old 07-17-2017, 04:14 AM
Drew Mazurek's Avatar
Quit PT.
open Console and in the hardware setup area put it in PT Mode.
launch PT.
go to I/O setup and in the bus tab hit default.
this should "reset" everything
www.drewmazurek.com
Old 07-17-2017, 04:27 AM
Thanks a lot !
It was in "PT mode in", i've turned off and now it's ok ! Mic 1 is in Mic 1 for PT!
Do you know what is PT mode and why it make that happen ?
Sorry for my english, I hope you will understand.
Alexis
Old 07-17-2017, 05:05 AM
PT Mode reorders the I/O to match inputs and outputs for outboard hardware inserts. Drew's resetting defaults should have worked also. If you ever need to use hardware inserts keep that in mind.
Old 07-17-2017, 07:55 AM
Thanks.
I think i have this problem now. I plug a bass in Hi-Z one, PT receive that on HI-Z one but now, when I put output 1, there's no signal in this output. Is there any mistake ?
Bass > HI Z-one > Input PT Hi Z-one > Output 1 in PT : No signal in line 1 behind the apollo.
Old 07-17-2017, 09:44 AM
I think you're mistakingly thinking that signals go from Console to PT and then back.
Console is your "input console". Once the signal is in PT, it will be processed and mixed there and does not need to come back into a channel in Console.
www.drewmazurek.com
Old 07-18-2017, 01:58 AM
So I think my question is :
How to correctly rout my output 1 from PT to the line 1 of the apollo ?
Old 07-18-2017, 03:19 AM
Not quite sure what the issue is, but try resetting the I/O setup by clicking the default button on the Input, Output and Bus tabs individually. I think option-click any default button will reset all, but don't know if that's still available since I/O setup has changed.
Old 07-18-2017, 04:14 AM
Why? What are you trying to accomplish?
How? Search the Apollo manual for Virtual Inputs.
www.drewmazurek.com
Problem with Pro Tools 9 and Profire 2626. Anybody have a solution to this problem? Priz Pro Tools Software (Win) 1 09-25-2011 12:51 PM
ELS Vocoder plugin problem and fresh Windows 7 install problem Thorpey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-09-2011 06:03 AM
Need opinions: Do I have Core card problem or computer problem? johnnyv Pro Tools TDM Systems (Mac) 2 08-11-2010 06:36 PM
Repeatable problem MP 7.4 upgraded to 8, ProFire 2626 problem tylerparkinson Pro Tools M-Powered (Mac) 0 08-21-2009 02:20 PM
Audio Regions Display Problem & Grabber Problem markus44uk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-25-2002 05:08 AM
