Old 07-11-2006, 12:36 PM
Ben83 Ben83 is offline
Default problem detected with audio clock Digi 002 rack
Yesterday I purchased a digi 002 rack, installed it following instructions and installed Pro Tools LE v 7.0. Everything seemed fine, but after importing audio tracks and wanted to press the play button the following message appeared: 'Problem detected with audio clock. Check that your clock source and sample rate are correct' . I've tried just about everything I could think of, but the message keeps popping up.. Pro Tools is also not recieving audio from the digi 002r. Can anybody help me out?
Old 07-12-2006, 04:26 PM
Mikeren Mikeren is offline
Default Re: problem detected with audio clock Digi 002 rack
Hi Ben,
Make sure that your hardware setup reflects "Internal Clock" and the sample rate that matches your project. The sample rate is the problem.
If you've imported audio tracks from a CD, for instance, the sample rate will be 44.1. If your project is created for 48K, you will get the message.
I don't have my system available right now. As long as you create a session at the correct rate initally, you'll be OK. In LE you'll also find a menu item (Hardware setup?) where you can check the settings and change them to match the imported files.
Happy recording,
MR
Learn to listen. Listen to learn.
Old 07-13-2006, 10:35 PM
jaymar jaymar is offline
I'm having this identical problem. Last time it showed up and went away seemingly on its own. Now, it's back. Any suggestions would be appreciated.
Problem detected with audio clock. Check your clock source and sample rate. sleeptalken Windows 7 08-10-2021 01:17 PM
Problem detected with audio clock. Check that your clock source and sample rate are c Solow1nonly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-06-2011 08:22 PM
problem detected with audio clock. check that your clock source and sample rate are c angeleda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-05-2010 07:09 PM
"Problem detected with audio clock. Check that your clock source and sample......... ASD15 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 03-26-2010 03:40 PM
Digi 002 R problem detected with audio clock. HELP :( thexflamesxburn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 06-11-2007 11:10 AM
