Old 07-26-2009, 10:00 AM
puckprotect puckprotect is offline
Default MIDI loop editing, "pattern style"?
When I edit looping MIDI drums would expect to work like this:
  1. Create (or import) a basic MIDI part for example 1 bar
  2. Set a number of loops, for example 8 bars, to be able to listen to the groove in different contexts
  3. Edit the basic MIDI part to improve the groove
  4. As a result, all 8 bars automatically get the same updates
However I try, point 4. fails. I have to manually apply the changes to all 8 bars, or Unloop/Loop the part again. Very unproductive.
I'm a bit of a newbie to PT LE 8, but I've tried reading the manual thouroghly and I haven't found any solution to working with MIDI loops in this kind of "pattern mode". I've also tried to search this forum.
Does anybody have an idea how to work productively in this situation?
PT LE 8, MBox Mini, Windows Vista
Old 07-26-2009, 10:50 AM
johnbhoy johnbhoy is offline
Default Re: MIDI loop editing, "pattern style"?
Switch on mirrored midi on the toolbar
Error: "Pro Tools cannot be put online while in loop play or loop record mode." msg6794 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-12-2016 06:09 AM
"Play MIDI Notes When Editing" Shortcut? Ru_C macOS 1 12-07-2013 08:49 AM
Keyboard shortcut to toggle "Play MIDI Notes When Editing" Soul Finger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-17-2010 06:29 PM
PTLe (Midi & Editing) D8b-Hdr (Audio) "Missed sync point...limit disk allocation" Amadeus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-16-2002 03:44 PM
What's the difference between "online" and "offline" editing ? stuu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-21-2002 03:46 PM
