  #31
Old 01-18-2019, 10:14 AM
Howardk Howardk is offline
Default Re: HDX PT 2018 CPU Spikes AAE -9171 Halts Playback
I tried testing in various video modes. . . such as DVI only on 20" monitor, DP only on 34", HDMI on 34", HDMI on 34" at half resolution. I did not perceive any difference and simple test session halted within a few minutes of running with 128 buffer.
I uninstalled the Avid Application Manager, and it seems to have made a slight difference. . . so far the test has run 54 minutes, but my system's performance and CPU spikes/Pro Tools Halts, have been inconsistent (like the weather), so hard to know just yet. I will run a bunch of tests. . . The center loading of the cores is still happening, and the CPU Total, is still jumping around a lot, which does not happen in my Pro Tools 10 (Mountain Lion) with HDX.
  #32
Old 01-18-2019, 12:58 PM
the.engineer the.engineer is offline
Howard, I am now test running a PCIe M.2 SSD blade running 10.12.6 Sierra and have just reinstalled PT Ultimate 2018.12 with all my plugs and had zero, I repeat zero problems today.
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
  #33
Old 01-18-2019, 02:48 PM
I hope it keeps working well for you!
Which PCIe card for the SSD blade?
  #34
Old 01-19-2019, 01:03 AM
Wolftech Pulsecard - PCIe 3.0 x4 adapter. The blade I'm running is the 256GB Samsing SM951 AHCI.
James Welch
  #35
Old 01-19-2019, 05:26 AM
Howard,
Is there anything else we've missed here with your setup? I'm sure there's something simple that's a quick fix. If it works here with my computer with the same setup there's got to be a way to get yours working.
Best,
James
James Welch
  #36
Old 01-19-2019, 10:47 AM
Originally Posted by the.engineer View Post
Howard,
Best,
James
I hope you are right. . . I have been having simple recording sessions with clients and getting by, but still getting the AAE 9171 even with a 512 buffer from time to time, and only running a couple AAX.Native Plugins.
The centre loading of the cores that I am seeing on my system seems to be what puts it over the top. I have been trying different test sessions, and I am finding that same issue. Plus the results are inconsistent. Sometimes it will have in 2/3/5 or 10 minutes before a Halt, and then sometimes it will go the full 2 hour test a couple times in a row without a halt. I have had tests successful with a 64 buffer for the full two hours, and had 512 halt. . . I can't see a causation or any pattern.
I would love to be able to try my test session on other computers, to see how they do and how the CPU core loading looks.
I am going to do a fresh install on a different SSD drive one more time.
  #37
Old 01-19-2019, 12:36 PM
Send your test session over (PM me) and tell me the parameters
James Welch
  #38
Old 01-19-2019, 05:09 PM
That would be great. . . I will PM in a bit. Thanks!
  #39
Old 01-19-2019, 11:12 PM
Ok, this may be promising. . . I was reading another thread it was suggested to someone else they just try running without the Pro Tools edit window displayed. . . so I did and the Total CPU meter spikes greatly reduce as soon as I close that window and the spikes come back as soon as the Edit Window is opened again.
I had tried my system on a smaller monitor, as well as different connections (HDMI, DP, and DVI), but did not notice an appreciable difference in CPU spikes on the meter, but I did have the Edit Window open in all cases (as I did with my PT 10 testing with HDX card and PT 10 did not show CPU Spikes).
I will run some more test rounds with the Edit/Mix windows closed.
Hoping all I need is a better video card, which I was hoping to upgrade for performance and be ready for Mojave in the future. . . but nothing local I can try. . . is there a clear winner for graphics card upgrade (would like to retain option to select startup disk, not exceed power supply)?
System Outline:
Mac Pro 2010 12 Core 2.93 GHz 48GB Sierra (10.12.6)
Video: ATI Radeon HD 5770, 34" LG SE790C (DP) 20" Dell 2005FPW (DVI @90 deg rotation)
Drives:
- System: OWC Mercury EXTREME Pro 6G SSD
- Sessions: Samsung SSD 850 EVO 500GB
- Samples: Samsung SSD 860 EVO 1TB
- Trim Enabled
- Sonnet Tempo SSD Card (PCIe 2xSSD), System and Sample SSDs
PCIe USB3/eSata Card (2x2)
PT Ultimate HDX 2018-12
Interfaces: Lynx Aurora16 x 2 + Digidesign 192 i/o x 2
  #40
Old 01-20-2019, 05:13 AM
This one will definitely work out the box
https://eshop.macsales.com/item/Sapphire/100352MAC2/
Can be tricky to come by though.
This one is in the UK https://www.ebay.co.uk/itm/Radeon-HD...28.m4335.l8656
But may also not have the right outputs for you.
I know you’ve already contacted macvidcards without success, but try again. My graphics card was flashed to show the grey boot screen by a guy in Poland who is a subsidiary of macvidcards.
James Welch
-9171 Errors luke88 Pro Tools HDX & HD Native Systems (Mac) 3 03-27-2019 03:49 AM
12.5 bug report AAE error -9171 solarduan Pro Tools 12 10 11-21-2016 09:29 AM
9171 error with HDX but not with Aggregate I/O pklein Pro Tools 12 0 07-15-2016 07:57 PM
Anyone having -9171/-9172 errors on 12? rinky Pro Tools 12 2 03-25-2015 10:32 AM
PT 11.2 with HDX 9171 error David Sandwisch Windows 5 12-02-2014 07:24 PM
