Best DI / Reamp solution?
Hello,
I need some professional help. First off, I have a diploma in audio engineering so I know more than the average person. I am going to be recording an album DI, and then will book an actual studio to reamp all of the tracks (Guitar, Bass, Synth, Vocals) and drums will be software/sample based. The solution I have been looking at is the Neve RNDI http://rupertneve.com/products/rndi/ into an interface (any suggestions?), and then into a reamp box in the studio. I also was planning on sampling at 24/192k...thoughts? Just wondering if any pros out there can give this newbie some guidance. Thanks for reading. |
Re: Best DI / Reamp solution?
Hi: welcome!
For reamping, Radial is very well known as a working solution, like the J48 http://www.radialeng.com/j48.php As an interface, depending on your budget you can explore between the Focusrite Clarett, Antelope Zen and Universal Audio Apollo. Regards.
Felipe Gonzalez A. Avid ACSR Elite Dante Certified http://felipousismix.wix.com/felipousismix Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins |
i have a little labs IBP .. i like that one ..
The RNDI is a good DI, as are the Radial ones mentioned. I have the Radial ProRMP and it works great for reamping and is inexpensive.
You may find you don't need to re-amp everything. You may like the bass more direct, and synths don't usually benefit from going through an amp (although why not?) I have found running my old Ensoniq ESQ-M through my Summit tube preamp and tube limiter does give a great sound going in, so there's no reason you couldn't pass the signals through good outboard gear in the studio and "re-amp" it to another channel so you have the direct and effected tracks. You might want to take advantage of all the EQ, dynamics and reverbs the studio has to offer. While plugins can get close, using a studio's echo chamber, or discrete EQ can make a difference.
Regards, Ned Monkey Boy Studios 2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3 Plugins, Virtual Instruments, and real ones |
I frankly don't understand how you make a record by listening to nothing but direct inject guitars and bass guitar and only imagining what those sounds will, you hope, one day be.
or, for that matter, how you get a great performance without hearing the actual guitar sound.
William Wittman Producer/Engineer (Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!) |
At the very least, throw a decent amp sim plug on there while you are tracking. The better amp sim plugs can sound pretty great. Try 'em out. Most players perform better in front of a real amp, though. Even better, print DI and a mic'ed cabinet to 2 tracks - a tried-and-true method. Or, use a Radial JD7 Injector to properly split the signal to multiple amps at once. Re 192k: not needed or practical. Move along. I'd expect the Neve DI will be great (never heard one), but there are LOTS of good DI options. Plus, a DI then needs to go into a decent mic pre... Another option is to skip the DI conversion electronics altogether, and plug right into an audio I/O interface that has a high-impedance -20db unbalanced input option (most do). The Radial J48 mentioned above is great. Finally, here is the secret to achieving the BEST tone ever (worth the time to watch): https://www.youtube.com/watch?v=dwEsjN6BEaE Good luck !!!
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Thanks everyone for your feedback!
Of course I will be using amp sim plugins to track with........I will then use the dry signals with my practice amp to sample the sounds! From what I can see the UAD interfaces seem to be best bang for the buck. You can even emulate hi end pre's :) Yeah, I wish I had +100k to book a studio, session players, and have it mixed/mastered properly. But with 2018 tech, and my abilites, it's now possible to make this happen on my own terms. I just may be able to save up enough for a day of tracking at one of the remaining world class studio's. And although there is definitely a glass ceiling on my plugin mixing/mastering techniques, I'm cool with that. I'm doing this for me. This album is going to be real, and from the deepest parts of my soul. Plus lately I've pretty much been metal AF so there's that too...... I'll post a link when it's done. Thanks for reading. https://goo.gl/DCqvuN __________________ ALIENWARE "I Am One With The Force and The Force Is With Me" Last edited by RockGuitar; 01-12-2018 at 06:42 AM. |
Hey, I'll do it for 99k !!!
Kidding aside - yes you CAN do it all yourself, but I would caution you to not wear too many hats. Writer, performer, producer, tracking engineer, mixing engineer, mastering engineer ... something's gonna give. Do what you are best at, and enlist pro help whenever feasible. Just a thought !!!
or do one job at a time .. write the tunes, then track the tunes, then mix the tunes, then master .. see what i mean !! don't try to jump ahead to fast ..
even if: you have a diploma in audio engineering and know more than the average person !!
One job at a time - vs - a diploma - vs - a lifetime of real-world pro experience (in any ONE area of expertise) are, well, VERY different. Can a top-tier concert master violinist "play" the 1st chair viola part? Uh ... maybe ... sorta. Even when you earn one diploma, it is in ONE area of study - NOT all related studies. That's my opinion !!!
Reamp 11R with 003 and Logic X | psychotoddler | Eleven Rack | 2 | 11-04-2013 04:48 AM |
11R Reamp through Axe FX | Webb | Eleven Rack | 12 | 09-27-2011 07:59 AM |
How do you Reamp using 11 Rack? | tom hess | Eleven Rack | 17 | 02-10-2011 08:04 AM |
Has Anyone Used REAMP with 001? | MissHiss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-26-2003 11:00 AM |
Reamp? | nz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-27-2000 11:33 AM |
