Old 01-14-2019, 02:24 PM
stevecomeau stevecomeau is offline
Default Dual Monitors Issue
Hi, I just upgraded my system to PT Version 2018.12.0 and now cannot stretch either my edit or mix windows across both screens. Early 2009 Mac Pro Mac OS 10.11.6. Any Ideas?
Old 01-15-2019, 05:55 AM
KV626's Avatar
KV626 KV626 is offline
Default Re: Dual Monitors Issue
Make sure that in your Mission Control preferences, "Displays have separate spaces" is unchecked.
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4
Arturia Keylab 88 Presonus Faderport 8 MOTU 896 iPad Air 2 w/ PT Control
NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc
Old 01-15-2019, 11:48 AM
Just tried that. Unfortunately didn’t solve the issue.
Old 01-21-2019, 07:58 PM
pot3 pot3 is offline
I have the same problem (desktop I7 3.3g 24gig ram win 10,
funny thing though I can not move the mix screan to the extended monitor but transport goes. can not extend the main protools screen either.
not too happy about it after a lot of buckazoids spent on upgrade.
also some times refuses to initiate sound?
Old 03-14-2019, 10:44 AM
synthpup synthpup is offline
Yes, I am having this issue as well. I'm trying to determine if it's an Avid or a Mac OS problem. I have some very intricate templates that I use that depend on changing a lot of windows configs. When I use a windows config now, the displays will collapse to a single monitor destroying the workflow and forcing me to pull the edit screen to the other monitor before moving on. The interesting thing is that everything seems to be fine if I use a very early, less developed version of the template (from 2017 PT 11 I think). This leads me to believe that it's an Avid problem.
I'm using a Mac Pro 5,1 , 2 NEC 1850E monitors, Mac OS 10.12.6, PT 2018.12
This problem needs to be fixed.
Dual Monitors Issue mrgroovy macOS 4 09-30-2017 07:24 PM
Dual monitors issue Paintedeyes Windows 63 02-22-2017 12:44 PM
Dual monitors: Can I have my mix and edit windows on different monitors? songwritersoul Pro Tools HDX & HD Native Systems (Win) 5 05-23-2014 11:16 AM
Dual Monitors TULL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 01-20-2005 04:07 PM
Dual Monitors PCI M2E Pro Tools TDM Systems (Mac) 1 05-01-2001 12:46 AM
