Win xp freezing when opening PT! Anyone else?
I've had a problem with Win xp freezing when I try to open PT. It doesn't happen consistently, but it does happen--and when it does, it's hard-core freezing (The only way out is to manually turn off the computer) I'm curious if anyone else has had this problem? And if it might be caused because I did not do a fresh install when I upgraded to XP.
And if I do decide to do a fresh install, do I need to delete and re-install all software and saved information on my computer? Thanks. |
Re: Win xp freezing when opening PT! Anyone else?
I am having a similar problem, but I can open protools just fine. however when i play back audio, after about 50 seconds it freezes hardcore as well (as you say it). what is your computer config? I'm running on winXP and did all those xp tweeks and it didn't seem to help all that much.
Asus a7v333 w/ XP2200+ maxtor 40GB and IBM 80GB (both 7200RPM) 512 DDR Matrox G450 Lite-on CDR can't think of anything else
i love apple. i love lamp. |
What XP tweaks? Let me know so I can do them. I really havn't done much configuring since I upgraded.
Also, can anyone tell me the optimum way to configure PT 5.3.1 with Windows XP? I have a PIII 800, 256RAM, XP home version, PT 001. |
sorry it took me so long to get back to you, i couldn't find where i saw them. anyways here are the tips i got off of someone in another forum...
http://www.musicxp.net/tuning_tips.htm goodluck, hopefully that helps you out (it didn't help me much).
Pro Tools freezing when opening a session | mike2205 | macOS | 0 | 02-24-2014 09:42 AM |
PT 11.02 freezing after closing a session and opening new session | asaffulks | Pro Tools HDX & HD Native Systems (Win) | 2 | 12-17-2013 01:49 PM |
Pro tools SLOW, and Freezing then continuing, then freezing again | DJX-RAY | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-09-2011 07:52 AM |
Session keeps freezing on opening when it is "Restoring Audio Engine Settings" | bradykrzemien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-18-2009 09:18 AM |
PT keeps FREEZING when opening session! Help! | jephreee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-28-2007 08:27 PM |
